Author Topic: mk2 golf gti 8v digi, turns over but wont fire up????  (Read 6737 times)
Offline newlad
Re: mk2 golf gti 8v digi, turns over but wont fire up????
« Reply #10 on: 03 January 2014, 10:11 »
Ok, I went to the car this morning, fuel pump still constantly on and no start, tried a few times and no joy, popped bonnet and played with red terminal on starter then she fired up, I suppose my main fear is the pump on constantly, what's causing it? Cheers
Offline Craigwilson
« Reply #11 on: 03 January 2014, 14:17 »
if the ecu is blown the pump will run constantly and the injectors (can be) stuck open this can do 2 things:
1. flood the engine and the plugs will be soaked and it will just turn over or not fire.
2. flood so badly it gets hydro locked with petrol and cant turn over.
this happened to me a few years back but the car would start if you let it sit a while then cranked the starter straight from ign off (no delay) or bump started it which probably wasnt good for it.
my oil was loaded with petrol after this, could cheeck and smell the oil to see if this is happening?
Offline Mr Blue
« Reply #12 on: 03 January 2014, 20:28 »
Yep if it constantly runs with ignition on...its blown. Not even a new replacement chip can fix it.
Make sure you have good earths. From battery to the chassis leg near battery and then goes to the gearbox. Now fit a new ecu...any digifant one works.
Offline newlad
« Reply #13 on: 04 January 2014, 09:20 »
So although the car starts just fine now,
despite the pump remaining on with egnition,
the ECU is still blown?
Offline Craigwilson
« Reply #14 on: 04 January 2014, 16:40 »
yes I drove for weeks with a blown ecu
Offline Mr Blue
« Reply #15 on: 04 January 2014, 19:33 »
hmmm double check the pump relay first in that case. check the whole fuse box while your there. moisture
Offline gazareth
« Reply #16 on: 05 January 2014, 15:48 »
 :shocked:didnt think you could drive them with a blown ecu! must affect the fuel economy slightly :grin:
Offline Craigwilson
« Reply #17 on: 05 January 2014, 16:06 »
I drove with one and it wasn't any different and the minute I replaced the ecu everything was back to normal
Offline newlad
« Reply #18 on: 18 January 2014, 21:40 »
so the car still running fine, fuel pump still on for more than 3secs when first turning key, (I'm looking at getting another ECU soon) but as the car idles every 30-50secs the car will rev and drop, just briefly but is quite annoying, any thoughts on this?
Offline notenoughtime
« Reply #19 on: 19 January 2014, 13:12 »
I think you should sort the ecu problem first before worrying about the other problem but could be air leak
