Author Topic: Coil packs  (Read 3774 times)
Offline budgie
Re: Coil packs
« Reply #10 on: 06 November 2013, 15:20 »
it might fit your car but cant see it being a genuine part  :sad:
if it gets rid of the crap the agu is having for just a day to drive to the dealers it,ll do me,lol
Offline dom
  • Back in a Mk4
Re: Coil packs
« Reply #11 on: 06 November 2013, 16:01 »
Have you checked to see if you are eligible for free coilpacks from VW under the recall?
Offline Dalo Harkin
Re: Coil packs
« Reply #12 on: 06 November 2013, 16:29 »
Have you checked the coil packs?
Start the engine and remove the coil pack harness from the coil pack itself, the engine note will drop, if it doesn't said coil pack is buggered. repeat on all until you find the dead one
Offline welshdean
Re: Coil packs
« Reply #13 on: 06 November 2013, 16:38 »
I've rang vw and they've told me that there wasn't a recall on my particular vin .
I've also disconnected the wires from the packs individually when the engine is running and they've all made a noise change.
Why do the parts on golfs have to be so expensive. Euro car are asking £90 for the ignition amplifier, and they reckon the list price is £240. Robbing f**k*rs
Offline Dalo Harkin
Re: Coil packs
« Reply #14 on: 06 November 2013, 16:52 »
if the noise changed it wont be the coil packs
Offline barrym381
Re: Coil packs
« Reply #15 on: 06 November 2013, 18:10 »
its an agu so they usually are bullet proof  :wink:
Offline Nino
  • Insta - F6UGA
Re: Coil packs
« Reply #16 on: 07 November 2013, 07:43 »
Dean try and put your standard airbox back on
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline budgie
Re: Coil packs
« Reply #17 on: 07 November 2013, 13:48 »
new ignition amp fitted and sounding sweet again :grin:  no more bubbly subaru sounds
Offline budgie
Re: Coil packs
« Reply #18 on: 10 November 2013, 12:26 »
any update? did you try the amp?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Coil packs
« Reply #19 on: 10 November 2013, 16:30 »
I fitted a non genuine one to mine, been good as gold ever since
