Author Topic: 16v and TDI clutch kit compatibility?  (Read 1729 times)
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« on: 05 November 2013, 13:23 »
http://www.ebay.co.uk/itm/400300439794?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Basically im sorting out what stuff I can utilise on a TDI from my 16v stockpile and one of the main parts ive got is a brand new Borg & Beck 3piece clutch kit as linked above.
I know that both these vehicles run the O2A gearboxes just with different gear ratios so theoretically it should fit but will it last any longer or shorter than a normal off the shelf TDI clutch kit due to the torque variation?
If its no good then il be selling it instead.
Offline gasketface
Re: 16v and TDI clutch kit compatibility?
« Reply #1 on: 05 November 2013, 14:32 »
this is probably long winded but i put the reg of both vehicles into eurocarparts part finder and cross reference the info and part numbers  :whistle:
« Reply #2 on: 05 November 2013, 14:37 »
I assume the same part numbers came up then, im not surprised to be honest but I only ask as I know the VR6 kits are slightly different even though its once again an O2A gearbox.
« Reply #3 on: 05 November 2013, 21:31 »
I am 99% sure it will work fine.
« Reply #4 on: 05 November 2013, 21:36 »
Well ive cross checked the part numbers in a  few different suppliers as mentioned above it would seem itll be fine which is certainly a  bonus. :smiley:
Offline Ben@VWH
« Reply #5 on: 06 November 2013, 10:28 »
Vw list the Abf as having the same pressure plate and friction plate as the 1Z tdi.  :smiley:
Both parts are different part no's on a vr6, not that that's really relevant, lol.
