Author Topic: MK4 1.8T starts then cuts straight out  (Read 9091 times)
Offline Ben@VWH
Re: MK4 1.8T starts then cuts straight out
« Reply #10 on: 08 November 2013, 09:15 »
What year/engine is the car?
Its W reg so 2000, MK4 5 door 1.8 Turbo
Im not sure of engine code?
post a pic of your engine, if it's a later type I can delete the immo for you.
Offline A5H
  • MK4 1.8 Turbo
« Reply #11 on: 08 November 2013, 10:47 »
Yes the fuel pumps makes a noise when you turn ignition on and when i try to start the car it smells of petrol bad for a few seconds
Offline A5H
  • MK4 1.8 Turbo
« Reply #12 on: 08 November 2013, 10:53 »
I beleive its immo 2 and the engine code is AGU
Check your PM  :smiley:
Offline Ben@VWH
« Reply #13 on: 08 November 2013, 11:48 »
Ah I can't do the agu ecu's. Anything 2000 onwards (aum,auq,arz etc) I can help with  :sad:
Offline A5H
  • MK4 1.8 Turbo
« Reply #14 on: 08 November 2013, 14:33 »
No problem, i think ive found someone who can but its a temp fix, il have to get new ECU clocks later and try them
I will let you know how i get on anyway
