Author Topic: new car new problem,lol  (Read 4008 times)
Offline dom
  • Back in a Mk4
Re: new car new problem,lol
« Reply #10 on: 01 November 2013, 09:47 »
First off scan it for fault codes  :wink:
This is the first step you need to take before spending any money on it.
Offline budgie
« Reply #11 on: 01 November 2013, 12:05 »
tried a hand held jobby and it didnt work. il have to find my proper cable :sad: and give it a try.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #12 on: 01 November 2013, 13:20 »
Just a warning, the AGU won't give many codes and definitely won't show the ignition amp as a fault
Offline houston
« Reply #13 on: 01 November 2013, 19:49 »
Ignition amp won't bring up a code, but if its an agu then 99.99% that's your problem. Sounds fine on idle but then a few revs and its burbles like an impreza.
Had the same on mine and got a 2nd hand amp for 20 off eBay. Had planned to replace with a new one if it cured the fault but its still going a year later with no trouble
Offline budgie
« Reply #14 on: 02 November 2013, 11:47 »
just a little juddery while sitting in idle, give it some revs and it burbles like a scooby
Offline budgie
« Reply #15 on: 05 November 2013, 10:49 »
well thats it gone in for a good service and ive also told them to run it through the computer, heres hoping it comes up with the problem.. if its coils will it show up??? already got a ignition amp on its way, should be here tomorow :smiley: and if thats not the problem well least i have a spare....
Offline barrym381
« Reply #16 on: 05 November 2013, 12:26 »
cant see a service helping much its more than likely the ignition amp with the symptoms you have posted an coil packs hardly ever fail on the agu  :smiley:
Offline budgie
« Reply #17 on: 05 November 2013, 13:11 »
i know but needed service anyway. garage just called. as people said no faults for coils or ignition amp but it is throwing up a code for the ECU??  would this be because its remaped tho?   told the man ive a ignition amp coming so il try that and if thats not the problem ive to put it back down to them :angry:..  heres hoping its the amp!!
Offline budgie
« Reply #18 on: 05 November 2013, 13:16 »
said it doesnt sound like a missfire just sounds like its running rough,,, no sh!t sherlock!!!!!!  il get it home and whip off the amp ready for my one coming tomorow.  when i said to him it may be the amp he asked whats that??????  he,s the mechanic,lol
Offline budgie
« Reply #19 on: 05 November 2013, 15:36 »
is it just a strait swap with amp? no neew to disconect battery ect,
