Author Topic: Arch removal  (Read 9785 times)
Offline Gti_Jamo
  • 1991 Corrado 1.8 G60
Re: Arch removal
« Reply #30 on: 08 November 2013, 16:56 »
On a more positive note, my arches were spotless upon removal of the plastics. Left them off and fitted cl side mouldings but with textured bumper tops, de-arching looks pretty gash to be honest. Mines rolls with its arches back on now.
Offline CraigBest
  • Golf Gti Mk3 Colour Concept Flash Red
Re: Arch removal
« Reply #31 on: 08 November 2013, 17:03 »
I'm probably going to put my arch back on when I get the new wing. Whatever's hiding under the other three can stay hidden.
Offline Foreveryoungaus16v
Re: Arch removal
« Reply #32 on: 08 November 2013, 18:18 »
De arching does look gash
163 BHP (TSR POWER RUN)
Offline CraigBest
Re: Arch removal
« Reply #33 on: 08 November 2013, 18:31 »
Everyone's entitled to their opinion. I like them with or without.
Offline CraigBest
Re: Arch removal
« Reply #34 on: 25 November 2013, 14:23 »
Going with the tiger seal, any advice on the key areas where to apply it on the arch covers?
Offline reddunk
  • VW Golf GTI MK3 Anni 8v
Re: Arch removal
« Reply #35 on: 23 January 2014, 22:59 »
is it not best to rivet them back on. just had one fall of due it being stuck on.  :angry:
Offline Screech16v
  • MK3 20vt AGU
Re: Arch removal
« Reply #36 on: 23 January 2014, 23:06 »
If they are stuck on properly then there would be no problem  :whistle:
Offline boneybradley
  • Back in a Mk3...
Re: Arch removal
« Reply #37 on: 24 January 2014, 00:00 »
Rivets as the mess tigerseal leaves behind is impossible to get off!!!
(plus for 16 black correct vw spec/odd size rivets it's only £3 at oemandmore.co.uk  :wink: )
Offline Callum_K
Re: Arch removal
« Reply #38 on: 27 January 2014, 10:26 »
Rivets are all well and good, unless you've had the arches rolled! I use PU40 adhesive from Toolstation...exactly the same as Tiger Seal etc but only £2.50!
