Author Topic: Ken's Golf mk2 GTD intercooler  (Read 246391 times)
Offline Ice_ken
Re: Ken's Golf mk2 GTD intercooler
« Reply #120 on: 27 November 2014, 10:42 »
found some nice stuff:
Offline Ice_ken
« Reply #121 on: 28 November 2014, 15:58 »
Something was wrong with the coolingsystem, I suspected it was the thermostat as the bottom of the radiator didn't get really warm. The fans didn't kick in aswell, it got worse and worse to the point where I had to do something:
so I orderd a new thermostat with a lower temp setting(80°C vs 87°C), when taking this apart and testing the old thermostat it became clear that i didn't fully opened. So I replaced the thermostat with the newer, colder type (bit of a pita because of PAS pump). New G12 coolant was added and voila, result:
perfect.:)
Offline Waspy
« Reply #122 on: 28 November 2014, 18:20 »
Good work and all,
I'm just jealous of that MPG   :laugh: 50 miles has hardly dented your fuel
Offline Ice_ken
« Reply #123 on: 28 November 2014, 18:55 »
Good work and all,
that's in km's actually. But it's been running stationairy for about an hour.
Offline Ice_ken
« Reply #124 on: 30 November 2014, 20:40 »
trial fit for the undertray, I didn't fit. It hits the PAS pump and wiechers brace.
So I orderd a seat toledo undertray.
fits nice underneath a mk2
Offline Ice_ken
« Reply #125 on: 01 December 2014, 16:28 »
Since I can't find the correct sensor, I wired the secundairy waterpump to a switch in the dash.
Offline logeyboy
« Reply #126 on: 02 December 2014, 08:53 »
I heard these fit, which model Toledo is it and do you have to do much to get it to fit?
Thanks
Offline Ice_ken
« Reply #127 on: 04 December 2014, 10:34 »
it's of a 1996 model, you have to cut of the leading edge, haven't fitted mine yet.
Offline Ice_ken
« Reply #128 on: 04 December 2014, 18:29 »
replaced the battery today, the new one has more capacity and higher coldstartcurrent while being lower so the IC cover could fit. I also took the time to straighten, clean and regrease the batteryconnectors,  and modify the cover that came with the battery.
almost done, pretty proud of this:
Offline Waspy
« Reply #129 on: 04 December 2014, 19:04 »
Understatement of the century
