Author Topic: Stop/Start  (Read 6488 times)
Offline monkeyhanger
Re: Stop/Start
« Reply #10 on: 28 October 2013, 19:42 »
It won't work on a GTD when a regen is happening either.
Offline Andyl
Re: Stop/Start
« Reply #11 on: 28 October 2013, 21:11 »
I thought just pressing the "A" button next to the gear lever disabled it ?
GTD, Oryx, Discover Pro, Dynaudio, DSG, Winter Pack, ACC, Air Bags, Park Assist, Keyless Entry
Offline harryhackenbacker
Re: Stop/Start
« Reply #12 on: 28 October 2013, 21:42 »
If you don't like the stop start ,get into the habit of hitting it every start (in my case hit the starter button &
the stop start overide button it becomes Habit ) if you want it back for a traffic jam or whatever just press again ,
on a DSG if you forget to disable it ,the car stops ,press the button and the car will re start and it will stay disabled .
Lots of Odd things happen with all these Gimos , No seat belt when putting the car in the garage will disable the brake
hold and auto parking brake for example ,  Keeps you on your toes  :laugh:
MK7 R 3 DOOR DSG PEARL BLACK FULL SPEC CARBON
LEATHER
Offline AlanH
Re: Stop/Start
« Reply #13 on: 10 November 2013, 14:29 »
Quick question on Stop/Start - if you park, prior to leaving the car, I'm assuming that the engine will stop. If so, is it still necessary to push the start/stop button to shut down everything completely before exiting the car?
Mk7 GTD | 3-door, Carbon Grey, Keyless, Dynaudio, Pano roof.
Offline adekil
Re: Stop/Start
« Reply #14 on: 10 November 2013, 14:50 »
Yep, look at Start/Stop as a 'Standby' function, if you get out the car without switching the engine off fully an alarm will sound warning you.
Current(2024): MK8 Golf R, Pure White, RV Camera & 19" Estoril Diamond Cut
Offline AlanH
Re: Stop/Start
« Reply #15 on: 10 November 2013, 14:57 »
Thanks adekil.
