Author Topic: First real minor critisim of the MK7  (Read 5807 times)
Offline monsta
Re: First real minor critisim of the MK7
« Reply #10 on: 21 October 2013, 19:43 »
why are people turning the air con off? leave mine on all the time in auto mode and if the screen fogs up (which it does) just blast it with the screen button.
Better fuel economy mostly  :wink:
Offline 2014GTi
  • Das Auto
« Reply #11 on: 21 October 2013, 19:43 »
Hi,
I dont need to get any fog in my Polo unless I leave the vent turned towards the windscreen.
Also I always turn off AC before turning off the car, this should close off all external AC inlet vents.
I trick to combat any moisture is to use the silica gel packets which you find in most electrical goods boxes and leave some in your car over night. This will soak up any moisture in the car.
You can also buy silica gel packets online, some which are re-usable once dried out.
 :cool:
2014 Volkswagen Golf GTi
2004 Volkswagen Golf R32
2011 Volkswagen Polo Bluemotion
2001 SEAT Arosa TDi S
1999 John Cooper Mini Works S
2005 Vauxhall Astra SRI CDTi
2002 Audi S3 quattro
1999 Peugeot 206 Grand Tourisme
Offline GolfTi
  • ..gotta feel for my automobile..
« Reply #12 on: 21 October 2013, 21:33 »
I've found that if you have air con on all of the time the problem is worse, maybe it stores the moisture somehow?
A clean with a good glass polish once a month helps a lot.
Mk7 GTI. DBP, DCC, Winter pack. Mine since new, July 2013.
GTI no. 4. Golf no. 5.  VW no. 7.
