Author Topic: Head gasket changed, still having problems.  (Read 2393 times)
Offline thomson07
« on: 19 October 2013, 19:12 »
My head gasket was changed about 1000 miles or so ago but im still having problems with the expansion tank.
Afetr a run in the car, the tank is either empty or bubbling and boiling.
There is still oil in the expansion tank, mostly on the surface.
The expansion tank will sometimes empty itself as soon as the engine is turned off.
Any point in changing the water pump / cambelt ? Or should I get the petrol and matches out......
Offline gazareth
Re: Head gasket changed, still having problems.
« Reply #1 on: 19 October 2013, 19:25 »
was the cylinder head skimmed?
Offline thomson07
« Reply #2 on: 19 October 2013, 21:14 »
yes it was skimmed
Offline beppe2672
« Reply #3 on: 19 October 2013, 22:15 »
Could it be the heat exchanger on top of the oil filter?
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline Chris#101
« Reply #4 on: 19 October 2013, 22:54 »
Was the system flushed and bled properly?
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline thomson07
« Reply #5 on: 20 October 2013, 09:31 »
As far as I know it was flushed and bled properly, tho the job was done in my works car park where the car broke down.
Offline harlemex
« Reply #6 on: 20 October 2013, 12:37 »
You may have a crack in your head, do a compression test.
Offline mar_k
« Reply #7 on: 20 October 2013, 18:42 »
Possible warped block?
I know some times people have them decked.
Just re-read the 1st post, Did you really go through the hassle of removing the head and not replacing the Cambelt and water pump?
At the very least you should have removed the pump for inspection.
« Last Edit: 20 October 2013, 18:44 by mar_k »
Offline thomson07
« Reply #8 on: 21 October 2013, 18:31 »
A mate did the job in my works car park, no access to full garage.
I didnt know that i should have changed pump and belt at the time, thats why i asked on here...
Offline EsSeX dAn
« Reply #9 on: 21 October 2013, 23:24 »
Sounds like (in no particular order)
head wasnt skimmed enough
warped block (pretty unlikley)
head bolts not torqued properly
possible faulty expansion cap
what engine wS it? do the heaters still get warm?
when you say the head tank goes dry, where does the water go or are you not too sure? get the car coolant tested and compression tested, thats all i can think of right now! its late lol
i think i love you.....
