Author Topic: Does any one know the law on protruding wheels from arch???  (Read 5835 times)
Offline gazareth
Re: Does any one know the law on protruding wheels from arch???
« Reply #20 on: 19 October 2013, 23:07 »
you could stick a mk2 gti axle on. should pull the wheels in just enough and if they in to far then you could space them back out slightly again.
Offline Shizzle
« Reply #21 on: 20 October 2013, 08:15 »
Yeh but gotta fine 1 for the full conversion.
MK3 Golf GTI 2.0 16v 3Door Storm Grey
Offline gazareth
« Reply #22 on: 20 October 2013, 11:10 »
but you just need the axle itself. everything else is interchangeable.
Offline hobbiniho
« Reply #23 on: 20 October 2013, 14:43 »
pretty sure that according to construction an use regs that anything protruding out past the wheel arch has to have a radius or more than 10mm and the lip of your wheels wont be 10mm so are technically illegal under construction and use and if you had a really informed copper could impound your car and give it an unfit certificate which would mean you need to get it motd again
Offline Shizzle
« Reply #24 on: 20 October 2013, 14:53 »
I live I police hell trafficops and police everywhere they dont evan look twice at my car round here they just dont care so until I sprt somthing I should be ok.
Offline tweed
« Reply #25 on: 20 October 2013, 16:48 »
Change beam? Christ bit much aint it?
Your poke is not a lot you can easily roll and push your aches out. Much faster and much less hassle. Of swapping beams hubs over.
I looked into narrow beam as I wanted to tuck 4" lips but the mk3 gti is quite narrow. The mk3 rear drum break beam is wide.
I think the mk2 beam is at the most 15mm shorter.
So is it worth doing for 7.5mm? No its not and thats why I didnt bother.  Only rute I had was cut and weld my beam but instead I went for 3" lips instead.
Offline Shizzle
« Reply #26 on: 20 October 2013, 17:16 »
If I roll arches can I still use plastic trim I have a arch roller at work?
VW BUSH
« Reply #27 on: 20 October 2013, 17:47 »
Seen Mk2 arches on Mk3's to give wider flair
Offline tweed
« Reply #28 on: 20 October 2013, 19:10 »
Yes trim the lip and glue them on.
I used no more nails vibration bond
Offline Shizzle
« Reply #29 on: 20 October 2013, 22:05 »
Will deffo give that a go as its free and effective thank you for all responses very helpful.
