Author Topic: Recommend me some uprated headlight bulbs  (Read 4283 times)
Offline Mattyj
Re: Recommend me some uprated headlight bulbs
« Reply #10 on: 05 January 2014, 15:14 »
I fitted osram nightbreaker unltd they are a whiter light and a bit brighter the side lights are phillps blue vision they are blue glass but i disagree in that i don't think they produce a white light they still look slightly yellow to me
Offline robw09
« Reply #11 on: 05 January 2014, 15:35 »
Sorry to piggy back on the back of the thread, but is there a way to remove the headlights so that I can replace the bulbs easier?  As I am really struggling to replace the bulbs.
Osram nightbreakers all the way!
Offline Mattyj
« Reply #12 on: 05 January 2014, 16:26 »
Which bulbs? Dipped are ok to replace not masses of room the side lights are attached via a push/clip in plastic holder drivers side ok use pointy pliers just pull stright bk pass i had to remove airbox for access remember when fitting bulbs wear gloves as if you get oils from your fingers on them you will great a hotspot and burn bulbs out quicker
Offline mustard
  • Mk7 R
« Reply #13 on: 05 January 2014, 18:37 »
You have to remove the bumper to remove the lights fully, however you can take out the top screws (there are some under the grille section), this allows a bit of movement. Be sure not to use too much force as you can break the bottom connectors and mark around the screws/washers to ensure that you do not mess up the adjustment.
