Author Topic: Shark fin roof antenna (mk6) is it for sat nav?  (Read 9716 times)
Offline Snoopy
  • Moderator
  • Geoff.
« Last Edit: 09 October 2013, 18:51 by Snoopy »
Mk6 GTI  &  Mk1 GTI
34 years of GTI ownership.
Offline dubber36
Re: Shark fin roof antenna (mk6) is it for sat nav?
« Reply #11 on: 10 October 2013, 12:04 »
http://www.my-gti.com/2742/aerial-information-for-volkswagen-golf-mark-vi
Read that it explains it all.
Not really. Unless I'm reading it wrong, every diagram in that link with a roof mount aerial is shown as being connected to a telephone. The Match model has Bluetooth, yet no roof aerial. I'm also pretty sure that later GTI/Ds from when bluetooth became standard don't have them either.
Offline mwad gti
« Reply #12 on: 10 October 2013, 13:16 »
The shark fin is FOR SATNAV
Candy White 3 dr Manual 2012 GTi. Bought new.
DAB, Dynaudio, Kenwood Head Unit Upgrade, Private Plate,
Full Leather and Heated Seats
18" Shadow Monzas, luxury pack.
Colour coded side skirts and gloss black diffuser.
Offline JoeGTI
« Reply #13 on: 10 October 2013, 17:27 »
I believe very early MK6's had a sharkfin if the car had factory fit bluetooth. But in later cars (late 2010 onwards, maybe earlier), the bluetooth was revised and it no longer needed the sharkfin. I think the earlier Bluetooth system was rSap which doesn't work with iPhones.
If you see a sharkfin on a later MK6 then it's got Sat Nav from the factory.
Offline MustardGTI
« Reply #14 on: 11 October 2013, 08:27 »
This makes sense. Mine has f/f bluetooth which will only work with certain older phones.
Looking on Autotrader, all the mk6 GTIs with sat nav have the fin.
Offline cosmicremedy
« Reply #15 on: 11 October 2013, 11:26 »
Makes Sense to me to, i have a March 2010 GTD, Sharkfin, bluetooth but it won't connect to my iphone  :sad:
Do want to get the Bluetooth going shortly, i take it, it would just require a new Bluetooth module (under the drivers seat?)
Offline MustardGTI
« Reply #16 on: 11 October 2013, 16:03 »
The small amount of research I've done suggests this is the case. Been quoted £300 for new module + the fitting from a couple of retro-fit companies.
Offline dubber36
Offline MustardGTI
« Reply #18 on: 11 October 2013, 21:18 »
£300? http://www.ebay.co.uk/itm/VW-BLUETOOTH-KIT-SEAT-SKODA-MFD3-RNS-510-RNS-310-RCD-510-RNS-315-5K0-035-730-D-/271293681244?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f2a5d0e5c
You wont need to use the harness, just unplug yours and plug the new one in.
Thanks for that dubber - I'll have to make enquiries about having it 'programmed in'.
Offline Neil gti
« Reply #19 on: 12 October 2013, 09:15 »
Just plug n play if you already have the older version factory fitted  :smiley:
Mine has a shark fin fitted and came without satnav but I have got Factory phone kit, (59 plate)
when I changed to Iphone a couple of years ago my kit didn't connect, got a newer version one off someone on the forum, and it was literally a 2 minute job on mine, uplug the old from under the drivers seat and plug the new one in, switch on and pair the phone with the kit.  :wink:
Mk6 Gti Gone but not forgtten
Loving the 7R
