Author Topic: VW Specialist couldn't fix my car... PLEASE HELP!!  (Read 5851 times)
Offline barrym381
Re: VW Specialist couldn't fix my car... PLEASE HELP!!
« Reply #10 on: 08 October 2013, 22:42 »
Hahaha I have don't worry! I don't have time to have a go at it till this weekend, I shall let you know what happens! Reckon it's worth unplugging it and giving it a run without the maf and see if there's any difference?
try it see what happens  :wink: an give vw a call about the coil packs your car might be due some free 1s
Offline Scott D
« Reply #11 on: 09 October 2013, 16:45 »
Has a different MAP sensor been tried at all?
Might be wrong on this one but issnt 17705 an issue with a bug in the ECU software that causes fault code even though no boost leaks?
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline dom
  • Back in a Mk4
« Reply #12 on: 09 October 2013, 18:27 »
As has already been suggested, ring VW to see if the car is eligible for free coil packs under the recall - even if the garage claims they aren't at fault new ones won't do any harm.
Definitely try running it with the MAF unplugged, they are very prone to failure and can cause the symptoms you have described.
If the MAF is at fault then make sure you get the replacement directly from VW, non-genuine ones are prone to failing prematurely.
Offline GTi_James
« Reply #13 on: 09 October 2013, 20:57 »
Clean it first with electric contact cleaner, 1.99 off the bay, cleaned mine Sunday as was revving erratically and boost gauge jumped to 0 and then back to normal constantly. Since then there has been no issues. Also that boost leak code was solved by niño by replacing all his vac pipes and fitting the forge 007p with free repair kit from forge and he doesn't have it anymore
Offline Nino
  • Insta - F6UGA
« Reply #14 on: 09 October 2013, 21:36 »
Yip, took me a crap load to fix my 17705, I don't know exactly what fixed it but i replaced the following...
* Changed the charge pipe for an AGU one, (Mine was AUM).
* Changed every single boost pipe to silicone.
* Changed DV to forge 007p & fitted a revised piston.
* Change TIP (Turbo inlet pipe) to silicone.
* Changed Rocker cover gasket.
* Changed Inlet manifold gasket.
* Did an N249 bypass.
* Changed Injector seals.
* Changed Injector seats for the Seat white revised ones.
Then and only then did my 17705 go away  :lipsrsealed:
Current - MK6 GTi Edition 35 - Candy White - 3 door.
Offline LaurenTBF
« Reply #15 on: 10 October 2013, 19:38 »
get some elctro spray to clear out the maf sensor, advise changing all boost pipes regardless of what they say, coil pack check etc, may be worth while changing you DV too
So I've given it a good old clean, put it back but where I've disconnected the battery and it's cleared the fault.. The bastard won't run. I completely forgot the garage told me it literally shuts down if the fault is cleared. Any ideas?? I'm at the end of my tether with this f**king this.
Anyone is manchester with VAGCOM that could help me??
Offline GTi_James
« Reply #16 on: 12 October 2013, 23:38 »
That shouldn't have happened tbh, you didn't move any of the fuses and you removed the negative first when disconnecting your battery?
Offline darren1.8t
  • I HATE FRENCH CARS
« Reply #17 on: 13 October 2013, 08:07 »
 try midland vw they are a sponsor on here they are the dogs balls they will sort the problem if they cant then no one can... also when you start the car do you get a sharp rattle noise??  as my cupra did what yours was doing and it was the chain tensioner was weak and telling the ecu to shut down?
Offline leigh_harty
  • Audi AGU
« Reply #18 on: 13 October 2013, 09:40 »
John Jeffers at JVW Leigh, might be abit out of the way but he's a top guy  :wink:
Dont lose your dinosaur!
Offline Dalo Harkin
« Reply #19 on: 13 October 2013, 10:16 »
I don't have full vagcom but I can check it over for you, I'm only in Stockport and can read and clear faults for you  :wink:
