Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120869 times)
Offline dv52
Re: MK7 and VCDS (VAG-COM) thread
« Reply #980 on: 02 February 2016, 04:37 »
I have a guestion i have a retrofit rear camera on my Golf everthing works fine only one thing when a reverse the shift the camera come one after drive forward on the navi screen the line with screen new destination my POI setup down the line wil not go away, only when i swing near the screen its go away.
Anyone have the same isue or did i code wrong?
cebbes: coding for installing rear view camera is:
STG 10> Coding> Byte 2 > Enable Bitt 4
STG 5F > Coding> Byte 19 > Enable Bit 4
Don
PS: Here are the screen shots
« Last Edit: 02 February 2016, 04:39 by dv52 »
103TSI Highline ROW (my13)
Offline cebbes30
« Reply #981 on: 03 February 2016, 00:49 »
Hello dv52,
I have made the right code already, but i think its the software of the navi maybe the iseu.
421 software discover media hardware 038.
Offline cebbes30
« Reply #982 on: 10 February 2016, 16:22 »
Whe i go fast backwards the camera switch off,( limit to ? km ) after forward driving the screen iseu what a have will go away like normal, but whe i drive veryy slow backwards and after switching forward the iseu come again and wont go away.
Only when push my hand to the Navi teh screen go normal.
Is it possible that you can change the speed km go back, from to max, maybe this is the problem.
Can anyone post a compare adpmap 10 adaptation, so i can look.
Offline Mark V GTD
« Reply #983 on: 26 February 2016, 10:55 »
Anyone know what happened to this channel:
Leuchte 12NL LB45-Lichtfunktion D13
I can't find it using any version of VCDS. Its part of the mods for fog lights coming on with main beam - the other channels are there but this one is missing - so strange.....
Offline dv52
« Reply #984 on: 26 February 2016, 11:41 »
Mark: I suspect the problem is in the "13". the real channel for the front, left fog-light is:(9)-Leuchte12NL LB45-Lichtfunktion D 12
Don
« Last Edit: 26 February 2016, 11:47 by dv52 »
Offline Mark V GTD
« Reply #985 on: 26 February 2016, 19:35 »
Thanks Don I will try that. Normally I would note any errors on my crib sheet at the time!
« Last Edit: 26 February 2016, 19:38 by Mark V GTD »
Offline Optimus prime
Re: MK7 and VCDS LED Indicator coding pls
« Reply #986 on: 08 April 2016, 13:55 »
Hi,
Does anyone have the coding for the led indicators to flash inner then outer or perhaps the other way around.  Both front & rear.
Thanks
Offline p3asa
« Reply #987 on: 08 April 2016, 14:07 »
« Last Edit: 08 April 2016, 14:18 by p3asa »
« Reply #988 on: 08 April 2016, 14:40 »
Here its here. I don't think you can get it for the front just the rear.
http://www.vwwatercooled.com.au/forums/f197/vcds-vag-com-codes-programmable-options-golf-mk7-84619-56.html#post1154325
Great thanks for the link has anyone bother to do it?  Also is it possible for the fronts as well?
Offline p3asa
« Reply #989 on: 08 April 2016, 14:42 »
The front is just a single bulb I think if you have the GTI/D. It might be LED in the R but it looks like one unit rather than 2 separate ones like the rear.
Yeah someone on here has activated it.
