Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120855 times)
Offline Optimus prime
Re: MK7 and VCDS (VAG-COM) thread
« Reply #910 on: 20 July 2015, 11:43 »
Anyone no the password to allow VCDS to start a dpf regen?
Thanks
Offline dv52
« Reply #911 on: 22 July 2015, 13:31 »
Hi
I am lans,owner of passat B8 2015 and a VCDS cable
i am trying to steal some knowledge,combining tweaks from Golf 7,octavia III and Leon and see which ones will work on my passat.
just wondering if anyone has ever thought of this
1. speed limiter to remain in power after ignition off. in my city the limit is 60kmh and fees are steep. is it possible to encode a permanent and default speed limit? or at least last known value on ignition off?
2. automatic all four indicators blinking when put in reverse,combined with mirror dip.
p.s.
mirrors unfold on unlocking the car,not on ignition on my passat
cheers
Lans: Hello - you ask some interesting questions indeed!
With respect to your question 2., I suspect that it is possible to light-up any of the rear lights when the car is put into reverse (but some regard needs to be given to heat stress on the blinker lamp holders). Not sure how familiar you are with Leuchte programming, but each of the mk7's exterior lights can be programmed to operate multiple functions. There are a sub group of Leuchte channels for each lamp that I have called an "alpha sub-set" and there are 8 of these for each lamp. This means that each lamp can perform up to 8 x different functions.
There is a setting for these alpha sub-sets called Rückfahrlicht (in German) which in English means reversing light. What this setting does is to illuminate the lamp whenever the car is put into reverse gear (this is the setting that is used for the actual reversing light on a mk7 - i.e. for the Leuchte28RFL LC11 channel set (left reverse light) & for the Leuchte29RFL RA64 channel set (right reverse light).
So to make the rear turn-signal lights light-up when the car is placed into reverse, you just need to find a spare alpha sub set on
Leuchte18BLK HLA60 (left rear turn signal), and  Leuchte19BLK HRC31 (right rear turn signal) and enter the setting "Rückfahrlicht".  You also need to alter the settings for  the corresponding "Dimmwert" and "Dimming Direction" channels. This will make the rear blinker lamps light-up whenever the car is placed in reverse (i.e. a solid light-not on/off like a blinker).
BUT there is a further consideration that needs to made (I think). I have read where some forum members have made changes to the blinker lamps to use them as brake lights only to find that they have melted the lamp holders. Blinkers have a 50% duty cycle which means that they are "pulsed" on/off, so the lamps holders won't sustain long on times. If you were to pursue my suggestion, I suspect that you should make the "Dimmwert" setting no higher than 50 (unless you have LED rear tail lamps.
Combining this tweak with mirror-dip isn't difficult (for the passenger side mirror) because this is the normal way that it works if your car has the memory capacity in the passenger side door controller
I have no answers for your other (good) questions but doubtless others here will be able to respond
Don
« Last Edit: 22 July 2015, 13:45 by dv52 »
103TSI Highline ROW (my13)
Offline bloggo
« Reply #912 on: 22 July 2015, 17:45 »
Hello Don,
I asked you a similar question as Lans on the VWW site:
[2. automatic all four indicators blinking when put in reverse,combined with mirror dip.]
With your helpful lighting guide I was able to illuminate the rear indicator lights when reverse was selected, as I did not want the front to operate:
 [So to make the rear turn-signal lights light-up when the car is placed into reverse, you just need to find a spare alpha sub set on Leuchte18BLK HLA60 (left rear turn signal), and Leuchte19BLK HRC31 (right rear turn signal) and enter the setting "Rückfahrlicht". You also need to alter the settings for the corresponding "Dimmwert" and "Dimming Direction" channels. This will make the rear blinker lamps light-up whenever the car is placed in reverse (i.e. a solid light-not on/off like a blinker).]
I also tried various combinations of the Alpha Sub-Set inserting "Blinken rechts Hellphase"  with "Rückfahrlicht"but was unable to get the blink operation to work.
Am I correct in assuming that it is not possible to make them blink?
Thanks
Bill.
Golf 7 GT 2013 1.4act, DSG,
Offline dv52
« Reply #913 on: 23 July 2015, 07:10 »
Hello Don,
Thanks
Bill.
Bill- Hello again - great to hear from you!!
Before I answer your question, I have to admit that there is much about Leuchte programming that I have yet to understand. This said, I am fairly confident in asserting that the only settings that are permissible for any of the 8  x alpha channels in a Leuchte set is listed in the table below (the same table is shown in my paper). The only setting that relates to reversing the car is setting ID #26 in the table.
As I said previously, this will illuminate the lamp solidly to the value that is set in the associated "Dimmwert" channel - alas it won't "blink" the lamp.
But I'm more than happy to be proven wrong in my assertion
Don
Offline bloggo
« Reply #914 on: 23 July 2015, 15:16 »
Hello Don,
This is what I found, after trying several configurations I could not get the lamps to blink.
I feel sure there must be a way of doing this and possibly it will be cracked in time.
Thanks for your reply.
Bill.
Offline lans
« Reply #915 on: 24 July 2015, 02:42 »
Hi
p.s.
cheers
Don
tnx for the reply
i have front basic led-reflector type
and rear basic led-the ones that stay horizontal while breaking.(the HIGH led rear,go vertical when you break)
so would you say that should bw no heat melting?
also,here is the scan from my passat for future use.
Tuesday,30,June,2015,16:15:50:25280
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
www.Ross-Tech.com
VIN: WVWZZZ3CZFE445322   License Plate: SK-6596 AI
Mileage: 5859   Repair Order:
Chassis Type: 3C (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
Address 01: Engine (J623-CRLB)       Labels: None
   Part No HW: 04L 907 309 R
   Component: R4 2,0L TDI   H21 0887
   Revision: B5H21---
   Coding: 0119003203441D083000
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_ECM20TDI01104L906026AS 001005
   ROD: EV_ECM20TDI01104L906026AS.rod
   VCID: 55ABB0FF346396896D9-8000
2 Faults Found:
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [032] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 4590 km
                    Date: 2015.06.12
                    Time: 14:32:30
20359 - Internal Control Module
          P0606 00 [101] - Processor Fault
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 572 km
                    Date: 2015.05.18
                    Time: 15:37:23
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 3Q0 907 379 F    HW: 3Q0 907 379 F
   Component: ESC           H42 0609
   Revision: 00000000    Serial number: 63514000002738
   Coding: 0EEC6A8F34240B71077A060241C54970562CD0E0608292F13460F078C002
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 3D7B085FAC136EC9459-8068
No fault code found.
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0356005419
   Coding: 000F0F0603
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 77F7DA77CEAF84995F5-8022
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5G0 907 044 AH    HW: 5G0 907 044 AH
   Component: Climatronic   H03 1001
   Revision: 00001K10
   Coding: 11020104202100012015500000101802
   ASAM Dataset: EV_ACClimaBHBVW37X 004131
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 6DDBF81FBCF33E49B59-8038
   Slave 1:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580501150888
   Coding: 00010A46C24102FF03A04084B11007081880000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 014004
   ROD: EV_BCMBOSCH_VW37.rod
   VCID: 7DFBC85FEC93AEC9059-8028
   Slave 1:
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119
   Component: WWS    141123  042 0607
   Serial number:         141201031904
   Coding: 0E4DDD
   Slave 2:
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S5Y15M01D08H10M04S24
   Coding: 00A8DD
   Slave 3:
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Component: E1 - LDS MQB  H01 0032
   Serial number: 16 11 2014  00000603
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY143210NWY
   Subsystem 5 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000061016863
1 Fault Found:
133387 - Voltage Supply; Terminal 30 for Central Locking
          B140F 13 [008] - Open Circuit
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0013
   Serial number: ATW-00111.01.15
   Coding: 0071061041
   Shop #: WSC 05311 115 00093
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_VW48.rod
   VCID: 3F877257A61F7CD9575-806A
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 2A40600310FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X_VW48.rod
   VCID: 336F2E679A57A8B9A3D-8066
1 Fault Found:
0862 - Databus
          U1123 00 [008] - Received Error Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 84
                    Mileage: 571 km
                    Date: 2015.05.18
                    Time: 10:46:39
Address 15: Airbags (J234)       Labels: 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2PSHT9S$
   Coding: 88CCC000000000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X_VW48.rod
   VCID: 0201BBA3956DD13178B-8057
   Crash sensor for side airbag; driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 912 14
   Component: SideSensor_Df  008 0887
   Serial number: 3576U00000079944E11E
   Coding: 2D2D2D
   Crash sensor for side airbag; front passenger side:
   Subsystem 2 - Part No SW: -----------    HW: 454 002 112 14
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U00000040330021M
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; driver side:
   Subsystem 3 - Part No SW: -----------    HW: 454 801 712 14
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R7CB566050000008
   Coding: 2D2D2D
   Crash sensor for side airbag; rear; passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 454 801 712 14
   Component: SideSensor_Pr  111 0148
   Serial number: 3526RFA546B05000000D
   Coding: 2D2D2D
   Crash sensor for front airbag; driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 512 14
   Component: FrontSensor_D  114 0149
   Serial number: 3556V0C5748050000005
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels: None
   Part No SW: 3Q0 953 521     HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0175
   Revision: FF032032    Serial number: 20150107400025
   Coding: 0000
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
Address 17: Instruments (J285)       Labels: None
   Part No SW: 3G0 920 741     HW: 3G0 920 741
   Component: KOMBI         209 4311
   Coding: 07A401102F80000800882A001001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   ROD: EV_DashBoardVDDMQBAB_SE25.rod
   VCID: 61C3942F702B6A29011-8034
Address 19: CAN Gateway (J533)       Labels: Redir Fail!
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2203
   Revision: --------    Serial number: 13121410803090
   Coding: 030300044F087300EF000258080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewConti 011020
   ROD: EV_GatewConti_VW37.rod
   VCID: 72E1EB63A5CDE1B168B-8027
   Alternator:
   Multifunction unit control module:
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H16 0040
   Serial number: 27140003140050104513
   Coding: 2CFFFF
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Component: J367-BDMHella  H04 8050
   Serial number: 2833385303
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
1 Fault Found:
8531970 - Quiescent Current
          U1406 00 [008] - Too High
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 21
                    Reset counter: 83
                    Mileage: 801 km
                    Date: 2015.05.20
                    Time: 00:33:01
Address 2B: Steer. Col. Lock (J764)       Labels: 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0031
   Serial number: 14000315541013
   Coding: 0000000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E3E46FA0CBDAA9911-8024
Address 42: Door Elect, Driver (J386)       Labels: None
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Component: TSG FS        020 0028
   Serial number: 111214BLA0672A
   Coding: 00350A20D000020000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 42817BA3D5ED113138B-8017
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E
   Component: Fond FHSG DRV  007 0002
   Serial number: 00000000000000643701
   Coding: 010000
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000115696
   Coding: 01010010005000
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_VW37.rod
   VCID: 3B7F0647B20760F97BD-806E
Address 52: Door Elect, Pass. (J387)       Labels: None
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0028
   Serial number: 171214BLG19605
   Coding: 00350020D000020000001000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 418374AFD0EB0A29211-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E
   Component: Fond FHSG PSG  007 0002
   Serial number: 00000000000000639417
   Coding: 090000
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
   Component: LWR-ECU       005 0080
   Revision: --------    Serial number: --------------
   Coding: 03DA000009000000
   Shop #: WSC 05311 000 00001
   ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
   ROD: EV_HeadlRegulVWLWRMQB_SE25.rod
   VCID: 75EBD07FD4A3F6894D9-8020
Address 5F: Information Electr. (J794)       Labels: None
   Part No SW: 3Q0 035 819     HW: 3Q0 035 819
   Component: MU-S--ER      H11 0135
   Serial number: VWZAZ2P4672212
   Coding: 02840100FF00000011110001000808001F0100840120010001
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_SK35.rod
   VCID: 6ED9FF13B1F5C5518C3-803B
   Media Player Position 1:
   Subsystem 1 - Part No SW: 3G0 919 605     HW: 3G0 919 605
   Component: ABT_Std-2  H42 1015
   Serial number: VWZ8Z9PD500879
1 Fault Found:
1555 - Check Software Version Management
          B201A 00 [009] -  -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 2
                    Mileage: 16 km
                    Date: 2011.05.01
                    Time: 00:25:51
End-------------------------(Elapsed Time: 04:19)--------------------------
Offline Silvadadi
« Reply #916 on: 05 August 2015, 22:39 »
Dv52/Don,
Have posted query about folding door mirrors being speed regulated.
Any ideas if this can be amended allowing them to fold regardless of vehicle speed?
Ordered Jun 18: R 5dr, IG, DSG, Prets, DLA, climate w/s and tints.
Aug 14 - Jul 18: GTD 5dr, CSG, DSG, S&S pack, Vienna leather and Santiago's.
Offline dv52
« Reply #917 on: 06 August 2015, 03:15 »
Dv52/Don,
Silvadadi: Hi
OK, I have to first admit that I don't have foldable mirrors on my mk7 and that my suggestion is -just a guess (apology)
I've had a good look through my database at possible ways of addressing your problem. Specifically, I have looked through all of the long-code Helper screens for the Passenger Door Controller (Address Hex52) and there appear to be no entries related to folding mirror switching speeds.
I then searched through the entire set of adaptation channels  for all the controllers in my mk7 - looking for anything that remotely related to switch-off speeds. There are over 3,000 adaptation channels in a mk7, but the search process is easy when the database is on a high order application like MS Excel.
Whilst there are 5 x channels related to folding mirrors in the BCM, there are no specific adaptation related to switching foldable mirrors. But, I'm guessing that the function could logically be tied to the park assist control module
Anyhow, to cut a long story short,  you could try the following (this is untested):
  • Select 10-Park/Steer Assist
  • Select Adaptation-10
  • From pull down screen select Switch-off speed for parking assist. You will note that the default value is 10 km/h
  • Change to a value that suits your requirement
Of course, changing this setting will affect all the other features related to park assist, but it's worth a try (I think). If it doesn't work, just revert the speed back to 10 km/h
Don
« Last Edit: 06 August 2015, 06:51 by dv52 »
Offline brenzef
« Reply #918 on: 06 August 2015, 09:17 »
Hi all,
I'm driving a Golf MK7 and I looking for two settings which I can't find.
I would like to disable the distance notification I see popping up all the time when I approach another car.
Useless and distracting if you ask me  :cool:
And...
I would like to have the audio volume set to zero (0) when I start the car. Currently the minimum value is 5.
Every time when I enter and start the car the music is playing at this minimum level (5).
Any ideas?
Thanks a lot...
« Last Edit: 06 August 2015, 09:29 by brenzef »
Offline Gnasher
  • Formerly GnasherVXR
« Reply #919 on: 06 August 2015, 09:44 »
Hi all,
And...
Any ideas?
Thanks a lot...
Can you set the maximum volume to 0 in the menus?
2014 Golf GTI (PP) in Pure White with
Vienna Leather, Keyless Entry, High Beam Assist, Park Assist, Rear View Camera. Milltek Exhaust, Eibach Sportlines, 19" BBS SR wheels - SOLD!!!!!
2018 Audi TTRS in Nardo Grey with
Black pack, 20" Alloys, Privacy glass and Sports Exhaust. No mods yet!
