Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1120872 times)
Offline Mark V GTD
Re: MK7 and VCDS (VAG-COM) thread
« Reply #840 on: 06 May 2015, 17:55 »
This happened to me and a kind person told me I need to do a factory re-set on the lighting set up in the central display and the changes will then take effect :-)
Offline UnSean
« Reply #841 on: 06 May 2015, 18:29 »
Ah, ok thanks I will try that.
Offline Sootchucker
« Reply #842 on: 12 May 2015, 08:03 »
Does anyone know what the minimum acceptable speeds are to get high beam assist activating at the slowest possible speed ?
As I understand it, the default values are first activate speed  - 57km/hr (approx 35mph) , speed at which deactivated - 27 km/hr (approx 16 mph) ?
Ideally, I'd like to get it to activate at around 20mph (approx 32 km/hr).
Also, am I right in assuming that to get the high beam assist to automatically re-activate after an engine re-start, it's just go into the Central Electronic Module, and change adaptation Channel 4 (Assistenzlichtfunktionen-Beam Assistant reset) to "active", and that's it ?
« Last Edit: 12 May 2015, 08:12 by Sootchucker »
Offline p3asa
« Reply #843 on: 12 May 2015, 10:50 »
Offline VW_rabbiter
« Reply #844 on: 14 May 2015, 10:16 »
try channel "No-Voltage display" and change to display.... battery state label does also not exist on mine but no voltage display works :)
Hi,
what does this "No-Voltage display" do?
Is it similar to State of Charge "SOC"?
Offline Jimble
  • Moderator
« Reply #845 on: 16 May 2015, 12:15 »
Quite like this, i think the guy that posted this is a member on here??
http://youtu.be/btIjbHvEeqU
Offline GrahamFR
« Reply #846 on: 16 May 2015, 12:19 »
Best mod ever imo :smiley: ive put the link to the code on here but who knows what page its on. Try mk7 golf indicator flash in YouTube, there is a Turkish guy with about 3 bids of it, one of them has the code in the comments
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline Jimble
  • Moderator
« Reply #847 on: 16 May 2015, 18:51 »
Does it only do it with the hazard lights or when indicating as well? Not sure i like it for the indicators tbh. :undecided:
Offline GrahamFR
« Reply #848 on: 16 May 2015, 20:24 »
Both I'm afraid but I think it looks cool still
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
Offline GrahamFR
« Reply #849 on: 19 May 2015, 08:01 »
Meant to say the coolest part of it is when you lock or unlock, very knightrider-esk!
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
