Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1121659 times)
Offline GeoBog
Re: MK7 and VCDS (VAG-COM) thread
« Reply #710 on: 03 March 2015, 18:13 »
If it was mean I would change the 1 and 2's to match, seems logical like the others, could it be driver and passenger?
I believe my R does the tear drop all the time, I want to turn it off, but just haven't played with VCDS much yet. I also have keyless.
Well I want the teardrop activated, wanna swap?  :grin: (only joking, I love my GTI)
Regarding the seats, I don't think it's the passenger as the entry in the adaptation channel says "Driver seat...". Could it be that the germans have missed this?
When you get a chance could you try activating the rain closing in VCDS and let us know if it works on your car with keyless?
« Last Edit: 03 March 2015, 18:14 by GeoBog »
2020 VW T-Cross SEL
2020 Renault Megane RS Trophy 300
2012 Fiat 500 Twinair
2007 Renault Megane 2
The two most important days in your life are the day you are born and the day you find out why.
Offline ajmoir36
« Reply #711 on: 03 March 2015, 18:18 »
I have scan which module has the tear drop? I can post my coding. Although I thought year drop was mentioned in the menu on the radio somewhere mind.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline GeoBog
« Reply #712 on: 04 March 2015, 12:28 »
That would be appreciated mate.
I've got no menu about tear drop wipers on my Infotainment.
2020 VW T-Cross SEL
Offline ajmoir36
« Reply #713 on: 04 March 2015, 18:29 »
Which module is it in?
Offline GeoBog
« Reply #714 on: 04 March 2015, 20:21 »
It is under 9 Central Electronics > Adaptation channels
2020 VW T-Cross SEL
Offline ajmoir36
« Reply #715 on: 04 March 2015, 20:50 »
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0134
   Serial number: 01011424700166
   Coding: 03011A46C24122F30BA44080B11C07281800000000000000000000000000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_BCMCONTI 013000
   ROD: EV_BCMBOSCH_SE37.rod
   VCID: 00057B509BF704216FB-8055
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    140825  042 0551
   Serial number:         140829062352
   Coding: 0E4DDD
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S5Y14M09D13H10M57S37
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY142110AQ1
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000060280718
Offline TurboTrev
« Reply #716 on: 04 March 2015, 22:03 »
Anyone know if the inner Golf 7R drl can be made brighter to match the outer?  Thanks.
Anyone cracked this yet?  Thanks.
Offline dv52
« Reply #717 on: 05 March 2015, 07:46 »
ajmoir36: The tear drop facility is not enabled by a Coding string change, it's enabled through the adaptation channels (as GeoBog has correctly said), The entries are in the BCM (address 09 -J519 as per your auto-scan extract above). There are two; one for the rear wiper and another for the front wiper.
The front wiper adaptation channels is:
(17)-Windshield wiper-Traenenwischen Front Status (rough translation (17) - Windshield wiper Tears wipe Front Status)
The rear Wiper adaptation channels is:
(4)-Rear Window Wiper-Traenenwischen Heck (translation (4) -Rear Window Wiper rear wipe tears)
The default setting for both channels is "not active". Change either, or both settings to "active". I haven't done this tweak, but I suspect that you will first need to enter the magic number 31347 into the security code
« Last Edit: 05 March 2015, 07:51 by dv52 »
103TSI Highline ROW (my13)
Offline capkapak
« Reply #718 on: 05 March 2015, 08:09 »
I've also tried this on my GTI and can confirm that it does not work either.
Offline fredgroves
« Reply #719 on: 05 March 2015, 10:23 »
What is "tear drop"?
