Author Topic: MK7 and VCDS (VAG-COM) thread  (Read 1121012 times)
Offline Mark V GTD
Re: MK7 and VCDS (VAG-COM) thread
« Reply #620 on: 23 November 2014, 13:10 »
Don't see how making that little change to the MFD display (I have done it myself) could have any bearing on ACC. If you are 100% certain that was the only change you made I would just take it to the dealer - as most likely just a coincidence...
« Last Edit: 23 November 2014, 16:04 by Mark V GTD »
Offline Ian.C
« Reply #621 on: 23 November 2014, 14:02 »
Might seem slightly random....but what is your SOC (state of charge) for the main car battery..?
Ken
3 Door - Pure White - PP
Offline dippy_x
« Reply #622 on: 23 November 2014, 15:26 »
Don't see how making that little change to the DIS siplay (I have it myself) could have any bearing on ACC. If you are 100% certain that was the only change you made I would just take it to the dealer - as most likely just a coincidence...
Yup - I have made that adjustment as well and ACC continues to function as normal.
On Order: 02/05/13
GTD: Carbon Grey, Winter Pack, Keyless, High Beam Assist, Park Assist, Rear View Camera, Furry Dice
Collected: 06/11/13
Offline roy2535
« Reply #623 on: 25 November 2014, 06:18 »
Could someone please kindly tell me how to mod the Long Coding on VCDS....I actually tried a couple times...either the change was rejected or the code just revert to default....Thanks...much appreciated
Offline Sootchucker
« Reply #624 on: 25 November 2014, 07:33 »
like Mark, I've had this mod on for over a month now and no issues at all with the ACC.
Methinks somethings actually wrong with the ACC and it's just co-incidence ?
Offline breezasib
« Reply #625 on: 25 November 2014, 09:22 »
Just turned off the soundaktor this morning and noticed two fault codes. Did a google and couldn't find what they mean but they do appear quite commonly in other peoples logs. Anyone know what they are?
Address 08: Auto HVAC (J255)       Labels: 5G0-907-044.clb
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120104202100011005000000101000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ACClimaBHBVW37X 003018
   ROD: EV_ACClimaBHBVW37X_VW37.rod
   VCID: 66ED5F7D9995F711F57-8033
2 Faults Found:
1048834 - Functional Limitation due to Energy Management
          B10CD 00 [009] -  -
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 27
                    Mileage: 12028 km
                    Date: 2014.11.25
                    Time: 08:32:35
1048835 - Functionality limited due to Engine Control Module
          P1719 00 [008] - -
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 28
                    Reset counter: 67
                    Mileage: 10800 km
                    Date: 2014.11.04
                    Time: 07:54:43
Offline itavaltalainen
« Reply #626 on: 25 November 2014, 22:55 »
These errors are probably due to stop start system; engine is stopped and then if climatronic would come on (say electric heater) it does not switch it on as battery level would go too low.
They are pretty sporadic and nearly every mk7 derivative I scanned had this at one point or another.
Offline led.737
« Reply #627 on: 09 December 2014, 15:31 »
Hello there!
Has anyone figured out how to link the mirror heater to the rear-window defroter yet??
Guess it's somewhere around module 09-Cent. Elet as it uses to be in other cars, but this module isn't fully mapped yet on VCDS 12.12. :cry:
Offline kevinm
« Reply #628 on: 09 December 2014, 19:11 »
Has anybody enabled this yet?  :cool:
Current: His: 2020 M340i   Hers: 2019 GTD
Previous:
2014 GTI PP DSG
GTI ED30 DSG
« Reply #629 on: 09 December 2014, 19:27 »
And it never will be on 12.12, so why not just download the current build from RT website?
