Author Topic: Lack of power, Engine Light on and cutting out Golf 1.8t  (Read 5815 times)
Offline Gabriel2202
Re: Lack of power, Engine Light on and cutting out Golf 1.8t
« Reply #10 on: 09 October 2013, 10:49 »
Also the temp is fine, gets to 90 and doesn't move at all. So that's good I guess
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline Nino
« Reply #11 on: 09 October 2013, 14:25 »
Well iys normal to hear that noise for a few seconds its the fuel pump and TB priming.
As for cleaning the sensors, dont use carb cleaner on the MAF use eletricail contact cleaner search youtube on "how to clean a maf" you should see little bits of black gine sand type stuff come out, best to clean your maf over a white peice of paper so you can see the dirt coning out.
A for that other sensor on the inlet, carb cleaner will be fine, just be careful you don't snap the resistor type thingy onit as they cost £70 to replace.
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline Gabriel2202
« Reply #12 on: 09 October 2013, 15:43 »
Cool thanks Nino - I'll post up later and let you know how it goes!
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline Gabriel2202
« Reply #13 on: 09 October 2013, 20:21 »
TB was the cleanest thing about my car! So I installed the camshaft sensor and went for a run, it cut out when I first started it but was fine after so hopefully it's fixed! Cheers for your help
Golf IV 1.8T AUM
Golf V GT TDI PD170
Offline Nino
« Reply #14 on: 09 October 2013, 21:30 »
Sweet beans, now clear your codes and hope they dont come back :)
