Author Topic: 280 brake upgrade  (Read 32357 times)
Offline Gambit
Re: 280 brake upgrade
« Reply #20 on: 30 November 2013, 14:54 »
They are the same kit for gti & g60
Offline Mcwill
« Reply #21 on: 30 November 2013, 17:18 »
Thanks for that gambit, what about the rear discs are all the gti ones the same.
Thanks rick
Offline Sgt_Lemon
  • 8v owners club
« Reply #22 on: 30 November 2013, 21:23 »
Is it worth putting drilled disks on the back? The brake bias is massively on the front brakes and I thought drilled/ vented disks were mainly for cooling to stop the brakes overheating. The amount of braking you would have to do to cook and warp the rear disks would have caused the fronts to go long before surely?
Offline Mcwill
« Reply #23 on: 30 November 2013, 21:31 »
But they will look good :wink:
Offline Gambit
« Reply #24 on: 30 November 2013, 23:00 »
Rear discs are all same size on gti/g60
Offline Diamond Hell
  • Opinions я Us
« Reply #25 on: 01 December 2013, 17:35 »
Don't do it.  Just run OEM discs on the back.  The holes just act as stress risers which will cause cracks in comparison to undrilled.
Waste of time/money/effort
Offline matt@onlychargeddubs
« Reply #26 on: 04 December 2013, 15:47 »
I'd say 280's will be fine up to 300bhp easily, 20mm won't make much difference at all, just buy very good discs and pads and you'll be fine.
I ran 280's with S2 twin pots, EBC discs and green stuff pads, G60 with 220+bhp that got stick daily, brakes never once faded, glazed or got pedal travel. Mine would hit 140mph easy, a 1.8T will probably see you over 150 but I wouldn't want to be doing that very often at all in a mk2 :grin:
