Author Topic: Water Methanol Injection  (Read 4657 times)
Online barrym381
Re: Water Methanol Injection
« Reply #10 on: 21 November 2015, 23:26 »
can wmi be used on stranded map
why not just get yours mapped  :smiley:
Offline markgti1.8t
« Reply #11 on: 22 November 2015, 00:27 »
need to get the turbo first want a k300 but think im just going to stick a k03s in the now soon as i find a good one
AGU fk coilovers Powerflex top mounts full 3inch decat turbo back viper induction kit fmic vr6 clutch g60 flywheel catch can 007 forge dv Power flex wishbone bushes  Power flex dog mount under brace JOM  ADJUSTABLE Drop Links Walbro 255lph INLINE Fuel Pump wmi now fitted WAITING TO FIT VR6 MAF SAAB RED TOP INJECTORS STILL TO BUY K300 TURBO  CON RODS LSD
Online barrym381
« Reply #12 on: 22 November 2015, 00:35 »
plenty of them about cheap  :smiley: not sure they would be any good though and if you have to factor in rebuild cost better just buying new hybrid
Offline rockmonkey69
« Reply #13 on: 22 November 2015, 17:54 »
OP: What psi did you set as full flow/max boost?
Offline markgti1.8t
« Reply #14 on: 22 November 2015, 18:45 »
starts at 6psi boosting up 2 12psi
« Reply #15 on: 22 November 2015, 18:47 »
As it's still standard, it might be too much to have full flow by 12psi, try setting the max flow for 20psi
Offline shaft69
« Reply #16 on: 25 November 2015, 23:10 »
Whats your max psi, where mounted nozzles and nozzles flow rates if know them. I run 270cc aquamist nozzle after fmic and run direct port and have 25cc nozzles in intake runners. Wmi start 15psi 100% at 25psi my max psi is 30. Need check timing pull with vagcom use that set wmi start. Id start wmi at half of your max psi and 100% couple psi before max psi and check timing pull and adj wmi start accordingly. Set up correctly its awesome takes time.
MK4 1.8t bored/stroked 2.0lt AEG crank, 83mm supertech pistons, intergrated rods, ACL race brgs, Flowed large port head, Supertech valves, All ARP bolts, GTX2871r turbo, Tial wastegate, 3" pipewerx dp, REVO stage 3 tune, Direct port water meth, MORE TO COME!!! Ready to go racing
Owner of bndynamix ltd. BMW and mini specialist
184 Wallgate, Wigan
WN3 4AL
07966492823.
« Reply #17 on: 26 November 2015, 18:34 »
His engine is running standard map.
Offline shaft69
« Reply #18 on: 26 November 2015, 19:24 »
What max psi on standard map?? Say standard map 10psi 150hp your nozzle will be pretty small around 150ml/min.
184 Wallgate, Wigan
WN3 4AL
07966492823.
