Author Topic: The weird green Ball thingy???  (Read 2743 times)
Offline [han]
  • Graphic Designer for Haribo
Re: The weird green Ball thingy???
« Reply #10 on: 18 August 2005, 23:20 »
so you were being serious, im sure it was called something else!! LOL! ahwell... it looks like one of them!! might clean my car tom seein as i have nowt else to do!
Offline Haribo!
« Reply #11 on: 18 August 2005, 23:38 »
i think it must be because i have a better carb , sorted, thankgod i dont need it, i chucked in a bush in frustration the other day
« Reply #12 on: 19 August 2005, 13:47 »
You might need it depending on how the carb is set up.  On a stock carbed model, theres a long green vacuum pipe from the thick brake servo vacuum tube, which runs round the front of the carb and splits into 2 pipes, one to the pull down unit and the other to the vacuum reservoir.
The one I'm talking about is labled A & B:
Offline Haribo!
« Reply #13 on: 19 August 2005, 14:29 »
weird, i dont have the green cable, i think my carb set up has been altered, i have no idea how or why, heres a good example, it started life with an automatic choke, but its had a manual choke put on it insted,
Offline [han]
« Reply #14 on: 19 August 2005, 18:19 »
yeah, i need a manual achoke puttin in.. automatic ones r naff.. miens rubbish first thing! as for this green ball thingy...
 this is the green ball in situe! lol... (the green ball thing.. funnily enough?!)
i made  my lil bro figure out what it is.. we're stumped... (well obv i am) one cable don't got anywhere and the other half of where it splits into 2 goes somewhere but we cudn't find it!)
« Reply #15 on: 19 August 2005, 18:43 »
Have a read through this:
http://www.golfgtiforum.co.uk/index.php?topic=18871.0
Tells you all about your carb, how it works and how to fix it :)
Offline sellers
  • Daz Works in Health and Beauty
« Reply #16 on: 20 August 2005, 13:58 »
if youve still got a pierburg carb it should have a small pipe coming from it to the carb and another air hose going from the carb, but iv you have a weber, you bypaas the carb and connect these 2 together, wil get a pic
Can't think of a funy or whitty comment
