Author Topic: What have you done to your MK 7 today ?  (Read 4917019 times)
Offline Ian.C
« Reply #960 on: 09 May 2014, 12:28 »
Got some Eibach springs fitted....ride quality is still very good and the drop is exactly what I wanted.
Ken
3 Door - Pure White - PP
Offline Booth11
« Reply #961 on: 09 May 2014, 13:02 »
Agreed, it seems a bit of a shame not to use LED's all round but you can swap them out for pennies...
All info here:
http://www.golfgtiforum.co.uk/index.php?topic=264345.0
Cheers.  Was just wondering as I'm changing to a mk7 R next year.  I swapped out all my current mk6 ones, so know it's cheap and easy.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Ginge 35Edition
« Reply #962 on: 09 May 2014, 21:40 »
Ken
That looks loads better, would look nice with some spacers now to widen the track a little too.
Offline Ian.C
« Reply #963 on: 09 May 2014, 22:32 »
Must admit....it had crossed my mind....a couple of problems for me...
1- Ive never had spacer before
2- Ive heard lots of bad stories about poor quality spacers
3- Im unsure what sort of size to fit
Any suggestions what make and thickness fit / look right.
Ian
Offline KyleB
« Reply #964 on: 09 May 2014, 22:37 »
Them Eibach's look spot on.
Offline Ian.C
« Reply #965 on: 09 May 2014, 22:44 »
Im really happy with them.....if it stops raining tomorrow ill get a better picture. Ride quality has hardly suffered and they seem to ride better at high speed rather than low speed for some reason.
Ian
Offline GrahamFR
« Reply #966 on: 09 May 2014, 22:45 »
Make sure they're hubcentric don't go for the cheapest ones, 10-20mm should do it, and make sure you get radial bolts
2007: Leon PD170
2010: Leon CR170
2013: Golf GTI PP
2016: A45 AMG
« Reply #967 on: 10 May 2014, 06:48 »
H&R hubcentric, 10mm on the rear with longer bolts and 5mm on the front, you'd have to check but you may not need longer bolts on the front.
I doubt you notice any handling differences but it'll make the car look wider but only slightly.
This is where I got mine from:-
http://www.dpmperformance.co.uk/golf-6-09-wheel-spacers-c-1909_2761_2951.html?zenid=48b355e02ec7fd7335749b0322d777d6
Offline Ian.C
« Reply #968 on: 10 May 2014, 17:29 »
Went out for a good drive today.....I was a bit nervous the sweet handling would be lost BUT the springs are great.....They have not compromised the shocks what so ever and the car still rides real nice over bumpy corners and the rebound is still sweet. Although its only a minimal drop its really surprising when sitting in the car you can feel the difference, makes it feel like your sat in the car rather than on it....if that makes sense.
Ken
« Reply #969 on: 10 May 2014, 19:04 »
Just been trawling through my photobucket account and found this, the picture makes the wheel look like it pokes from the arch on the 10mm spacer but it actually sat flush.
Not sure if this helps or not?
