Author Topic: What have you done to your MK 7 today ?  (Read 4916956 times)
Offline EINZ CLUBSPORT
  • 2016 GTI Clubsport
« Reply #8710 on: 19 July 2018, 06:04 »
Installed VWR Springs today and did APR stage 1 yesterday.  :laugh:
Offline deltarikk
« Reply #8711 on: 19 July 2018, 11:54 »
Sounds like a good couple of days to me EINZ! ......car looks great  :wink:
Offline rwleigh
  • Richard.
« Reply #8712 on: 19 July 2018, 14:05 »
Looks good, what's the ride like now?
Golf GTI CS40 #010 | Manual | 5 door | Pure White | Car-Net | 90% tints | Winter Pack | REVO stage 1
« Reply #8713 on: 20 July 2018, 01:22 »
Cheers guys. I wish the CSG or Urano Grey was sold in NZ, its my favourite colour!
I'm really enjoying the stage 1 power now and the ride is definitely improved. I leave it in comfort mode mostly for daily driving, Sport mode is firmer for sure and noticeable. The drive-ability to me is the same as its not lowered too much about 15mm or so. I think its a worthwhile upgrade for sure. I'm guessing the springs still need a few more K's to settle a bit more.
Offline Watts
« Reply #8714 on: 20 July 2018, 12:29 »
Finally got my 42 Draft Designs shifter bracket bushes in the post today:
Now all I've got to do is fit them and the new to me bracket. But will they make any difference? :undecided:
Previously:
Offline kalimon
  • My other car's a van
« Reply #8715 on: 20 July 2018, 13:07 »
You're obsessed with the damn gear change on your GTI!!
Just get a DSG already :laugh:
5 DR Mk 7 GTI PP
Offline Watts
« Reply #8716 on: 20 July 2018, 13:27 »
Guilty as charged Your Honour :laugh:
I bought a manual to enjoy changing gears so a bit of fiddling keeps me out of trouble and may improve the driving experience :smiley:
Previously:
Offline Watts
« Reply #8717 on: 20 July 2018, 17:44 »
Got my metal bracket and solid bushes fitted :smiley:
A bit tricky to see it and just as fiddly to change. Having already changed the lever I thought it should be pretty straightforward but the cable clips were a pita to get off (I'm sure they were a lot easier last time :undecided:) and everything was just awkward to get to. Still, got it changed and then adjusted the shift cables which is where I really got into some bother. I used a 5mm drill bit to lock the lever, on the first attempt reverse get jumping back out, on the second attempt 2nd and 4th wouldn't engage and that's where it remained for several other attempts :angry: I must admit to an air of panic... As it turned out my 5mm drill bit when measured turned out to be more like 4mm. After a frantic hunt to find something else suitable, I found the chuck key from my ancient Bosch drill fitted a treat and on the first attempt all gears including reverse worked perfectly :smiley:
So, was it all worth it? I've only had a quick drive to my local supermarket so far but it does feel better, a bit more precise, smoother, very positive. But whether that's due to the new parts or the cable adjustment, I'm not sure. :whistle:
Previously:
Offline andy28
« Reply #8718 on: 21 July 2018, 19:35 »
Removed the baked on bugs from the front of my car. It took a while but it looks so much better now...
GTI Clubsport Edition 40
#301 and then #190
Offline Davey-c
« Reply #8719 on: 21 July 2018, 19:55 »
Looking good Andy. Mine needs done but I’ve got a long drive next week so will clean it once I get back.👍🏻
2023 Golf R 20 Years, Lapiz Blue, 19 Inch Black Estoril Alloys, Rear Camera, Harmon Kardon Sound System.
