Author Topic: What have you done to your MK 7 today ?  (Read 4916939 times)
Offline Watts
« Reply #8080 on: 01 February 2018, 16:02 »
Given up on getting cf mirror caps so decided to get the common back ones :rolleyes: Wanted to wash the car before fitting but at the rate I'm going it'll be spring before that happens. Gave them a couple of coats of wax before fitting and I'm very pleased with them :smiley:
I preferred the black and red carbon ones :whistle:
Joking, they will look good with the other black bits on the car.
See! I knew they were tasteful! :whistle:
Thanks, the other 'black' bits are likely to remain manky brown for some time but I think it's going to look much better. Mind you, I really need to grow up and not be bothered by such triviality :rolleyes:
Previously:
Offline I wanted a GTi
« Reply #8081 on: 01 February 2018, 17:27 »
They'll be the same colour in a few miles.
Offline SRGTD
« Reply #8082 on: 01 February 2018, 22:31 »
@Watts; They look good. New black wheels to match next then?
My car cleaning OCD would mean I’d really struggle with a combination of spotlessly clean mirrors but a dirty car. :shocked:, so I’d have to had waited until I washed the car before fitting the mirror covers. :grin:
It would give me an incentive to clean the car though.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Watts
« Reply #8083 on: 01 February 2018, 23:12 »
No, I'm sticking with the wheels! I really didn't want to fit them to a dirty car but I just can't find a combination of off, dry and able - last wash was at the end of November :embarrassed: Next purchase will probably be a DA :whistle:
Previously:
Offline Sootchucker
« Reply #8084 on: 02 February 2018, 08:49 »
Installed better LED bulbs for the front and rear footwell lighting. They actually aren't quite as bright as the image here makes out, I think the camera is just more sensitive to red light.
Offline o`Neil
« Reply #8085 on: 02 February 2018, 08:53 »
My next purchase too, I was actually looking at them last night but don`t know where the hell to start, more research needed  :smiley:
Offline Watts
« Reply #8086 on: 02 February 2018, 09:27 »
Headover to the detailing section, plenty of threads on there with advice. I think I'm going to go with this one - http://www.cleanyourcar.co.uk/polishing-machines/das-6-pro-dual-action-polisher/das-6-pro-meguiars-microfiber-system/prod_963.html - a good combination of performance and price. The Meguiars system has been recommended too.
Previously:
« Reply #8087 on: 02 February 2018, 11:42 »
I'm worried for Watts when he buys the DA, I'm not sure how he will take the shock of opening his wallet that far :whistle: :laugh:
Offline Booth11
« Reply #8088 on: 02 February 2018, 11:43 »
Jesus!  Haven’t you bought one yet!  Cars will be extinct by the time you clear the moths out of your wallet.  :grin:
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Booth11
« Reply #8089 on: 02 February 2018, 11:51 »
Do a search, plenty of recommendations in the detailing section.  Look at kits to get you started.  Some threads here, with recommendations and links to kits.
http://www.golfgtiforum.co.uk/index.php?topic=276899.msg2530314#msg2530314
http://www.golfgtiforum.co.uk/index.php?topic=280786.0
Have a read of some of this thread below from reply #1432 to #1455,which discusses important factors such as choosing a DA that will take both full size pads and spot pads (different backing plates) as not all do.  As a first DA I would advise you choose one that takes both to give you maximum flexibility.
http://www.golfgtiforum.co.uk/index.php?topic=274783.msg2578069#msg2578069
Also think about the ‘throw’ of the DA. They range from 8” throw to 15” to 21”.  The ‘throw’ is the measurement that the plate moves/oscillates in a random rotation, and determines how much ground is covered during the oscillation of the plate/pad.  The bigger the throw the more ground covered, so more ground with less effort, but also less control.  Larger throw is better when you’ve got a bit of experience under your belt.  8” is good to start of with, and often larger throw machines have a different backing plate assembly so don’t take the aforementioned spot pats which hugely limits things.
« Last Edit: 02 February 2018, 11:57 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
