Author Topic: What have you done to your MK 7 today ?  (Read 4846301 times)
Offline Booth11
« Reply #7980 on: 18 January 2018, 09:33 »
I don't understand why you'd want to turn AC off?
Climate control is a wonderful thing, apart from anything else, it keeps the windows clear most of the time.
Agreed. Much better all round to leave aircon running all year round, be it auto or customised. Much healthier for the whole system. All those who regularly post up issues with aircon and misting etc are those that don’t run it all year round.  Not a coincidence.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline SRGTD
« Reply #7981 on: 18 January 2018, 10:38 »
+1. Air con isn’t just for cooling the interior of the car during warmer summer months. It also dehumidifies the air in the car, so helps prevent misting up during the cooler months. I’ve always run mine 24/7; and I don’t experience the misting up issues some others have.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline Jeni_R_
« Reply #7982 on: 18 January 2018, 10:45 »
purely because i felt running the AC used more fuel - perhaps i am wrong ?
Offline dubber36
« Reply #7983 on: 18 January 2018, 10:55 »
Do a test with or without. It makes virtually no difference to fuel consumption. Having to pay an extra penny per litre for fuel would cost you more over a tank full of fuel than using the air con. That's something we all do without giving it much thought.
Offline MattCupra
« Reply #7984 on: 18 January 2018, 10:58 »
Does the 7.5 have the info screen that shows how much fuel each of the cars systems is using, like it does on the 7 ??
Offline Booth11
« Reply #7985 on: 18 January 2018, 11:03 »
As said the cost of running aircon all year is negligible.  As mentioned above, if you go into your CAR menu, one of the scroll screens shows just what each system is using if you need to know.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Jeni_R_
« Reply #7986 on: 18 January 2018, 11:21 »
Ok Ok i am converted i shall run with it - i just need to work out the coding to turn that off after so many minutes VWJAP any ideas :)
Offline fredgroves
« Reply #7987 on: 18 January 2018, 11:34 »
Some things, its labelled "convenience consumers" and it gives a figure for gallons per hour.
I can't remember if AC is one of them, certainly heated screen,  heated mirrors and heated seats appear on there.
But yes, of course AC does consume fuel, it can't appear from nowhere, that's basic physics but having climate control and the windows shut of course reduces the amount it consumes.
It will use more energy cooling or heating to a temperature than keeping it there.
Seriously Jeni, its the least of your problems and avoids other more expensive problems (like moisture build up in the car or needing your aircon cleaning out due to non-use)
Offline Sootchucker
« Reply #7988 on: 18 January 2018, 11:42 »
Also don't forget in the HVAC menu, you can set the intensity (how much the AC compressor runs) from Eco, Normal or Intensive, if you do what to throttle it back a bit.
Offline Booth11
« Reply #7989 on: 18 January 2018, 12:03 »
Coding to turn the aircon off?  Perhaps I’m misunderstanding you, but most of us here are suggesting you don’t turn it off, but run aircon all the time for all the reasons given.  Or are you talking about turning something else off?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
