Author Topic: What have you done to your MK 7 today ?  (Read 4846298 times)
Offline Watts
« Reply #7380 on: 17 October 2017, 17:55 »
Ordered a clutch stop. It reduces clutch pedal travel and has been highly recommended on many forums. For around £17 I thought it worth a go especially when I checked last night and roughly 40% of pedal travel seems unnecessary :rolleyes: Hopefully it'll also allow me to sit 1 seat adjustment further back which I find more comfortable but difficult to fully depress the clutch. Just one of a few minor mods I'm planning as and when funds allow including an Audi short shift and metal shift bracket with upgraded linkage bushes. Will try removing the clutch assist spring and delay valve plus if I can really stretch my wallet I would like to replace the lower engine mount with an upgraded VWR billet version, the dogbone inserts to me seem a bit of a bodge albeit a cost effective one. I just fancy getting my hands a little bit dirty under the bonnet and feel more involved with my car and how it performs :smiley:
Where did you order the clutch stop from?
Can confirm the clutch assist spring and delay valve removal are worthwhile mods, as is the dogbone mount insert. :smug:
Ebay, comes from the US and has some adjustment via the removal of washers. Nice and easy plus cheap, my kind of mod :whistle: Good to hear your feedback on the other changes, might take a look tomorrow at the spring. I may still go down the route of the insert as the full new mount is over £250 which smarts a bit :shocked:
Previously:
Offline Booth11
« Reply #7381 on: 17 October 2017, 18:04 »
Bought it a present.  Latest addition to the detailing arsenal.  Rupes Mini Bigfoot for spot work.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline 7MAT
« Reply #7382 on: 17 October 2017, 18:59 »
Very nice, have a few Rupes machines myself.  :grin:
MK7.5 Golf GTI Performance, 3 door, Issac Blue, DCC, Manual. Racingline Stage 1 OEM+, Remus Exhaust system, Sache Performance Clutch.
Offline I wanted a GTi
« Reply #7383 on: 17 October 2017, 19:13 »
Do you have a link Watts?
I washed the sand and ash off the car this evening. I was going to photos but it was getting dark and I thought a beer was more important.
Offline Watts
« Reply #7384 on: 17 October 2017, 19:37 »
http://www.ebay.co.uk/itm/VW-AUDI-PERFORMANCE-CLUTCH-STOP-GOLF-MK6-MK7-GTI-R-SCIROCCO-A3-S3-TT-SEOTLEON-/331207149596?hash=item4d1d7c081c:g:zvwAAOxyF0pTgS2v
Previously:
Offline clubsport
« Reply #7385 on: 17 October 2017, 20:03 »
Interesting, do you know the approximate depth or thickness that works?
I appreciate it has shims, but looks like a very easy thing to make.
Cheers.
Offline Watts
« Reply #7386 on: 17 October 2017, 20:12 »
Cheers.
I don't, will happily let you know once I get it but I reckon a bit of experimentation with whatever you choose as an alternative wouldn't take too long. Reading around I saw that one person had made their own using a doorstop.
Previously:
Offline clubsport
« Reply #7387 on: 17 October 2017, 20:26 »
That's exactly what I was thinking, a rubber door stop and velcro over the original mounting hole.... trial and error will decide if velcro is strong enough other wise mount it on a plastic trim screw... easy!? :)
http://www.wickes.co.uk/Wickes-PVC-Door-Stop-Black-28mm/p/103306?CAWELAID=120135120001182807&CAGPSPN=pla&CAAGID=52608959424&CATCI=pla-350975526687&gclid=Cj0KCQjw1JbPBRCrARIsAOKj2PmCrfMo4apFowuGtcpOIjyR7oCvpoau6MhTs8R9EEsZjshjYwdIGIsaAmAQEALw_wcB&gclsrc=aw.ds
Or if I am not feeling quite so extrvagant!
http://www.wilko.com/all-hardware/wilko-rubber-door-stop-black-round/invt/0345046
Such bespoke modifications would no doubt enhance the value of the car. ;)
« Last Edit: 17 October 2017, 20:33 by clubsport »
Offline Watts
« Reply #7388 on: 17 October 2017, 20:55 »
Perhaps a bolt through the middle to locate it in the right place with a circular double sided sticky pad with a hole in the middle (for the bolt) to hold it?
Previously:
« Reply #7389 on: 17 October 2017, 21:34 »
Cheers Watts, ordered and in your post you said £17 which is a bargain but the link says £7(ish) which is a steal.
