Author Topic: What have you done to your MK 7 today ?  (Read 4916956 times)
Offline Booth11
« Reply #6770 on: 10 June 2017, 18:22 »
Its good stuff Booth, I had a creak on the dash of my wife merc, slipped in a little of this and bingo !
Yeah I know, used it on my mk6 for same problem.  Never without a bottle.  If you have a Golf, you should have a bottle of Krytox, lol.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Booth11
« Reply #6771 on: 10 June 2017, 18:23 »
Good tips, thanks for posting, mine is creaking worse than ever despite a few coats of the stuff - I think I've been too mean with it.
How frugal were you with it?
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline JoeGTI
« Reply #6772 on: 10 June 2017, 18:30 »
I'm amazed you lasted this long before needing to lube those seals. I had to do that within a matter of months of getting the car. Same with the previous.
Offline Watts
« Reply #6773 on: 10 June 2017, 18:36 »
Fingertip approach and only around the top of the door seals, not down the sides. It usually helps eliminate most noise but lasts only about a week. Also wasn't doing the felt seals until a week or two ago, all I have are streaks down the glass and more noise than ever! I'll have another go following your tips and hopefully that should sort it.
Previously:
Offline Booth11
« Reply #6774 on: 10 June 2017, 19:11 »
So am I Joe, longer than I expected, the seals in the mk6 needed doing after 16 months so I got away with an extra 4 months with the R, lol. I think it's because (and this can actually work against you too) I often wax around the inside of the door (not the seals), which stops the waterfall of rain off the roof but also seems to keep seal creaking at bay for longer, but people have had this actually cause creaking.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline Booth11
« Reply #6775 on: 10 June 2017, 19:15 »
Do the lot Watts.  Basically where there's contact with rubber/seal/felt where the door closes, it gets Krytox'd. Key is to make sure they are wiped down with IPA first as if they are greasy or have wax on then the oil won't absorb properly.  If it rains you will get some wreaking but wiping off excess after application minimises this.
« Last Edit: 10 June 2017, 19:17 by Booth11 »
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline I wanted a GTi
« Reply #6776 on: 10 June 2017, 19:30 »
That's because you live in the west of Ireland and Rebecca lives in the southeast of England Joe :whistle:
Offline JoeGTI
« Reply #6777 on: 10 June 2017, 22:02 »
Ha, that could be a factor.
Offline Booth11
« Reply #6778 on: 11 June 2017, 15:40 »
Cleaned it.
2012 MK6 GTI DSG
2008 MK5 GTI DSG
2005 MK5 GTI Manual
Offline dereks
« Reply #6779 on: 11 June 2017, 15:55 »
Looks amazing^ was in the dealer today to hopefully change the GTi to a used R left it with them to find a suitable spec.
