Author Topic: What have you done to your MK 7 today ?  (Read 4916956 times)
Offline monkeyhanger
« Reply #3140 on: 07 October 2015, 19:01 »
Let me know when you want to meet up for vcds Matt.
Thanks Chris - the wife's A1 could do with a few items too (needle sweep, mirror dip and something else I can't remember). So they seemingly knocked the Soundator back up, but the volume fill lyou put on is still there.
Offline Watts
« Reply #3141 on: 08 October 2015, 15:57 »
Today I removed all four wheels and gave them a good clean and a wax. Two coats on the inner surfaces. Also gave the calipers back their lovely red shine. Wheel bolts seemed a bit too easy to undo but I used my torque wrench to tighten them properly.
Wasn't overly impressed to find one of the disc retaining screws fall out as I removed the wheel.
Also, as it wasn't specified in the handbook, does anyone know what the recommended number of times to scrape your knuckles on the ground is when using the supplied jack?
Previously:
Offline Pinky1959
« Reply #3142 on: 08 October 2015, 18:49 »
I took wheels off both cars earlier this year to clean them ,
 you should buy a trolley jack it makes removal a lot easier and you then don't have to use the car jack.
Offline Watts
« Reply #3143 on: 08 October 2015, 19:11 »
Good advice but you're talking to an idiot. I have a trolley jack but it's buried in the shed and I can't be arsed to dig it out!
Previously:
Offline Bungleaio
« Reply #3144 on: 08 October 2015, 20:28 »
What did I do? I saw it for the first time!!!
Picking it up next Thursday, I'm going to struggle to get any sleep before then.
Abarth 595 Turismo + Classic Mini + Triumph Street Triple RS
Did have 3door DBP GTI PP
Offline MXResonance
« Reply #3145 on: 08 October 2015, 20:35 »
The ride height looks so high in those photos, I'm guessing the transport pucks give the car extra height?
Golf Mk7 GTI - DSG, Performance Pack, 5 Door, Pure White, 18" Austin, Discover Navigation, Keyless Entry, Factory Window Tints, Winter Pack - Collected 30/09/2015
Offline Bungleaio
« Reply #3146 on: 08 October 2015, 20:45 »
I was hoping that too, if not some springs will be in order. I've not even got it and plans for mods have started creeping into my head  :whistle:
Offline Tornado8
« Reply #3147 on: 08 October 2015, 21:45 »
Fitted DTUK Pedal box after much cussing(very tight connections).Now playing with settings, on standard sport mode at the moment. Much improved response at lower revs to go with the REVO stage 2 tune. Also have 034 Motorsport dogbone insert(CNC machined). Better response than the Neuspeed insert and seems to be less vibration :smiley:
Old, but a serial modder!
Offline BigD
« Reply #3148 on: 10 October 2015, 17:01 »
Pressed plates and a GTI surround
Offline phope
« Reply #3149 on: 10 October 2015, 18:53 »
Not far from my office :)
Golf Mk8 R order cancelled...awaiting company car instead
Tiguan 1.5 Elegance for the wife & dogs
Skoda 1.5 SEL cheap lease special
