Author Topic: What have you done to your MK 7 today ?  (Read 4885210 times)
Offline Adam T7
« Reply #14050 on: 24 January 2026, 16:21 »
Reasonable day here today so managed a decent wash and wax and cleaned underside.
« Last Edit: 24 January 2026, 16:25 by Adam T7 »
Offline A-Kai
« Reply #14051 on: 25 January 2026, 00:56 »
Fitted some actual winter tyres and drove to the northern most part of The Netherlands, where it’s been dumping fresh powder every day. Fair to say that my PS4S’ would’ve killed me by now. Bonus: there is something oddly satisfying about a white car on fresh snow.
How did you find the car in the snow? Have recently picked up a set of wheels with winter tyres as I'm planning on driving to the alps for a ski trip. From what I've read they seem to cope fine with good tyres - time will tell!
Car felt well planted and barely triggered the traction control, despite the constant sound of snow and sloshing all around. Good rubber is vital. For reference, I have a set of 19” Hanook Winter i*cept evo3 on with approx. 7mm thread all round, which are a good mid-premium range tyre. They got me through heavy snow just fine, and I passed several cars on All Season tyres awaiting recovery.
That’s being said, the roads leading to ski resorts are usually well maintained, so I’m sure you’ll be fine! If the car does lose traction. I found it to be easily controllable as long as you’re driving smoothly.
Offline A-Kai
« Reply #14052 on: 25 January 2026, 00:59 »
Looks immaculate! Any tips + equipment for doing the underside? Looking to give it a good clean this spring.
Offline Adam T7
« Reply #14053 on: 25 January 2026, 06:21 »
I use on of these short vario lances on the end of my Karcher gun, have it at 90 degrees and it removes salt and road crud easily enough. I use it medium power, it’s a bit to fierce on full. About £15.00 off eBay for a Karcher copy.
Offline MervJnr
« Reply #14054 on: 26 January 2026, 13:00 »
Good to know, thanks for the feedback! Funnily enough they are the tyres I'll be using, albeit on 17" wheels. Test fitted yesterday - clears the PP front brakes so should be all good! May take some chains as a fall back.
« Last Edit: 26 January 2026, 13:33 by MervJnr »
Offline A-Kai
« Reply #14055 on: 28 January 2026, 16:49 »
Much appreciated! Thank you!
Good luck, and safe travels!
Offline willni
« Reply #14056 on: 01 February 2026, 18:42 »
Starting to suspect I have a failing mechatronics unit in my gearbox.
Holding 2nd gear past 4k rpm
If I drop gears to overtake i.e 7th to 5th, gearbox hesitates and what I would describe as a bunny hop / loss of traction.
Hoping it's an engine mount or another mount, but unfortunately this is the 3rd in the family with the same symptoms as the other two cars, all coincidentally around the 50k mark.
Unfortunately I like the car too much still so will have to stomach it.
Offline david25
« Reply #14057 on: 02 February 2026, 13:53 »
Hope you have a warranty!
Now = 2011 MK6 GTI - Reflex Silver
Past = 2006 MK5 GTI - Tornado Red and Solid Black
Offline Bluest
« Reply #14058 on: 03 February 2026, 14:45 »
My passenger side mirror glass fell out. Somehow it didn't break, so I've stuck it back in
Offline willni
« Reply #14059 on: 07 February 2026, 10:09 »
Ran diagnostics on my car after remembering how a coil pack through big errors into a friends car including engine light and gearbox don't drive errors. Cylinder 4 has a heavy misfire (24 misfires over 300m on live diag) so I've ordered a new coil pack to at the least sort that but with the aim to sort the gearbox hopping issue I've had.
Update Rev K to Rev P coil pack, finished the misfire which in turn fixed the gearbox issue.
Also I got a notification about the Performance Pack front caliper plates coming into stock on Ebay today (Link below to one example) if anyone else has been trying to get OEM plates instead of stickers. Ended up ordering two myself.
Part no. 5G0698221
https://www.ebay.co.uk/itm/127669012842?_skw=5G0698221&itmmeta=01KGVRX6XNG5FH2YMDG6MVP6KR&hash=item1db9aa896a:g:FRUAAeSwqxhpheAF&itmprp=enc%3AAQALAAAA4GfYFPkwiKCW4ZNSs2u11xDWyePbb9qKuKv0wZMrVfW2%2BTXZCoMGAleVyeqbYX%2BehXNIzNjNXH9%2B3%2B9eah3YSjmqnY2NoSjnsItWkR9n5NrBZmaWru9jm49ycqBevUv0IEBfTGODoQNO%2B41SSpMljWngh0YbEKjxxxKdiOe8VxYh6EJkQ9BJVn%2BHi7AfsdqDQdS1ugMGdY44R20pl4Y%2Bc8w%2FxC7V6GSGhYViUg6%2Fqp0lcQLO3XbqV6MLD62gcMfNtRHaig5TNDMhPyupiORUkp97YhLod5X9EgxNZFELMVeG%7Ctkp%3ABFBMgu_0-IZn
« Last Edit: 09 February 2026, 19:05 by willni »
