Author Topic: What have you done to your MK 7 today ?  (Read 4693987 times)
Online Watts
« Reply #13300 on: 28 January 2024, 15:53 »
Went to the VSCC driving tests day at Brooklands. Seeing 1920s and 30s cars being driven hard is great. As it was such a lovely day, had the sunroof open on the way home, first use this year. I don't have enough hair to feel the wind through it but it was nice to feel some fresh air for a change!
Previously:
Offline Paul70
« Reply #13301 on: 29 January 2024, 21:05 »
Changed the thermostat housing and water pump. Quite a job, but new parts fitted, coolant bled and first drive done and coolant level stable.
2026 Golf GTI ED50
Offline Paul70
« Reply #13302 on: 29 January 2024, 21:11 »
Removed the wheel arch liners and gave the surrounding areas a good clean. No sign of corrosion- I was a little concerned after watching Volkswizard’s recent post
2026 Golf GTI ED50
Offline sal1m
« Reply #13303 on: 30 January 2024, 23:07 »
Rear wiper reinstall and rear spoiler removed
2015 golf 7 gtd
Offline oryx3dr
« Reply #13304 on: 01 February 2024, 14:52 »
Lowering springs installed today. I'd kept some spacers from my previous Golf and fully intended on fitting them today when I got the car home, got the spacers out of the shed but for some reason it seems I've got rid of the bolts!  :undecided:
What size do people recommend for good fitment with Brescia's?
Current - 2020 Black Golf GTI Performance Pack DSG, Sunroof, Dynaudio, Climate Windscreen, Brescia's
Sold - 2017 MK7 Oryx White 3dr GTI
Sold - 2019 Up GTI
Online willni
« Reply #13305 on: 01 February 2024, 15:13 »
I run 8mm and 12mm but why not just buy the bolts? instead of buying a full new set of spacers and bolts?
Offline sjw
« Reply #13306 on: 01 February 2024, 15:29 »
I've got 15mm on the front and 20mm on the back and it looks pretty spot on, but I get a tiny bit of rubbing on the front if I go down a dip too quickly. Haven't yet taken the screw out of the liner to see if that makes a difference.
Offline oryx3dr
« Reply #13307 on: 01 February 2024, 16:07 »
Yeah that's the plan just wondering what people run on the front. I need to double check but I'm fairly certain I've got 15mm ones currently so might go for a 10/12 up front maybe.
Sold - 2019 Up GTI
Online Watts
« Reply #13308 on: 01 February 2024, 17:15 »
Got mine booked in for a thorough clean inside and out with a local detailer. For various reasons washing it myself is just never going to happen. If that goes well I may see about a paint correction at some point but I will need to get a regular slot for a maintenance clean.
Previously:
Offline oryx3dr
« Reply #13309 on: 01 February 2024, 20:03 »
Spacers ordered for the front and bolts for the back. 40mm is the correct length for 15mm spacers?
Sold - 2019 Up GTI
