Author Topic: What have you done to your MK 7 today ?  (Read 4916994 times)
Offline RM
« Reply #11330 on: 12 May 2021, 07:53 »
Thanks for the eBay link, Watts. What size is typically needed to do all doors on a 5-door?
Offline Watts
« Reply #11331 on: 12 May 2021, 08:33 »
In the post I linked above it was said that 30ml should do for 3 uses. Not sure what that equates to in grammes as in the ebay ad. Perhaps 10g would do? The bottle I have is tiny and has been used a few times but is still going. Not sure what quantity/weight it was, I'll have a look later.
Previously:
Offline willni
Offline RM
« Reply #11333 on: 12 May 2021, 12:49 »
Thanks, I’ve taken a gamble on a 20g bottle in the hope it’ll cover two cars… time will tell.
Offline Watts
« Reply #11334 on: 12 May 2021, 13:36 »
Mine is 10g. It's covered my current car (although sunroof yet to be done) and it did my previous car (3 door) and I lent it to someone to do their car too. There's a little left too say I'd say you should be fine!
Previously:
Offline sjw
« Reply #11335 on: 12 May 2021, 14:34 »
Took my first drive after replacing an ignition coil to resolve my "hopping" issue I posted about a few months back (doesn't time fly?)
OBDEleven helped to debug as a misfire, as did googling on a whim "mk7 gti drives like it has hiccups" :laugh: Turns out "hiccups" is a common term
Offline willni
« Reply #11336 on: 14 May 2021, 09:51 »
Nothing too exciting my new mats arrived along with my last clubsport centre cap.
Offline dobb3r
« Reply #11337 on: 14 May 2021, 11:10 »
Fitted some DSG paddles to replace the tiny oem ones, much better.
2019 White TCR, 5 door, DCC.
Offline willni
« Reply #11338 on: 14 May 2021, 11:17 »
Look great mate! I prefer seeing them on your car than hiding in my drawer collecting dust!
Offline My other womans a vw.
« Reply #11339 on: 14 May 2021, 19:04 »
willni,i have the same mats in mine-well,sort of.
They look great,but are susceptible to heel imprints after very little use,making them look like you’ve had them for years.
So much so,I purchased some genuine rubber mats and swapped the drivers mat for the rubber one,as it was doing my head in,the rubber mat being more robust for daily driving.
Mats are often reinforced or double layered on the heel area-you see this on cheaper ones,you’d think for the price these gti mats are,vw could have done better.
Or it could just be my size 11 feet that’s the issue!
