Author Topic: What have you done to your MK 7 today ?  (Read 4816022 times)
Offline willni
« Reply #11270 on: 19 April 2021, 08:07 »
Looking great :smiley: As an alternative, how about Reifnitz? A good looking wheel, a little unusual and not diamond cut. Should look great with TR.
if you can find some. Reps you can but genuine ones, no chance.
I thought about the Reifnitz but decided against them as it could become a replica TCR, especially since I really wanted a TCR but my budget didn't stretch that far. If I had a Pure Grey TCR I'd definitely go a Satin Bronze in them though.  :smiley:
I'll most likely go with the Brescias so I can reuse my Michelin PS4S's, as well as it will help break up the Black and Red theme on the car.
« Last Edit: 19 April 2021, 08:09 by willni »
Offline oryx3dr
« Reply #11271 on: 20 April 2021, 10:45 »
Upgraded my screen to the 8" glass screen from the new 7.5s. Looks much better and also an absolute bargain for £80 (although £147 for the trim surround is a joke).
Current - 2020 Black Golf GTI Performance Pack DSG, Sunroof, Dynaudio, Climate Windscreen, Brescia's
Sold - 2017 MK7 Oryx White 3dr GTI
Sold - 2019 Up GTI
Offline mcmaddy
« Reply #11272 on: 20 April 2021, 11:48 »
isn't the trim supposed to match the the climate trim and the cover below??
Offline Ryan90GTI
« Reply #11273 on: 20 April 2021, 22:57 »
I can't see anything other than an upsidedown volume button 😵‍💫
Offline SRGTD
« Reply #11274 on: 20 April 2021, 23:22 »
I’m glad it’s not just me then :grin:. The volume knob in my car is always the correct way up - volume can only be adjusted by the driver using the steering wheel volume buttons. :smiley:
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline oryx3dr
« Reply #11275 on: 21 April 2021, 10:28 »
I Will eventually switch them all out but will have to stay like that for a while
« Last Edit: 21 April 2021, 14:08 by oryx3dr »
Sold - 2019 Up GTI
Offline Norwich7point5
« Reply #11276 on: 21 April 2021, 12:59 »
Exactly the same here. The missus reckons I have severe issues... :laugh:
2017 mk7.5 Indium Grey Metallic GTI - 3 door - Manual - Art Velours - Brescia 19s - No fog lights!
Offline Paul70
« Reply #11277 on: 21 April 2021, 14:22 »
Great upgrade, I did the same mod last year.
The colour of the trim section you have bought is from a lower model Golf 7.5, so I would not recommend changing all trim parts to match the colour of the new trim section. I would recommend you change to the Gloss Black trim the GTI had in MK7.5 guise. Perhaps you can take that part back to VW and explain.
2026 Golf GTI ED50
Offline sjw
« Reply #11278 on: 21 April 2021, 15:24 »
Checked my spark plugs, trying to determine the source of the "hopping" issue I have had a thread going on about.
How do they look? https://photos.app.goo.gl/iUb5Qk37xLms4PyWA
I've been swapping coils etc to try and locate the cause, but typically, every time I am trying to test, it doesn't happen!
The other day, the car juddered a LOT and I had to pull over, EPC light was on and the car was in limp mode. OBDEleven diagnosed it as a misfire on cylinder 1. Later, I tried it out again, and saw multiple (>10) misfires on Cyl 1, a few (<5) on 2 and 4, and none on 3. I swapped 1 and 3, but I haven't had any drives where it's generated an appreciable number on any coil in particular. Maybe 2 in 10 miles.
Are a few misfires ok? Or should I be working harder to track the problem? I'm just going to be waiting for it to start happening again which, now the weather is warmer, doesn't seem to be as often  :huh:
Offline Lordie
« Reply #11279 on: 21 April 2021, 17:24 »
I can't believe how many people are freaked out by the volume dial not being perfectly upright :grin: Some people have some serious OCD on here
