Author Topic: Is there anyway to tell whether its the temp sender or thermostat  (Read 3140 times)
Offline mar_k
When my stat went the temp would drop to almost nothing on the motorway,
Completely stuck open it was. I used a circoli stat to replace it and it worked fine ever since
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Sender is dual circuit, one tells the ECU the temp for fuelling purposes the other tells the gauge what to read.
Stat usually makes the car take ages to get to temp and drops during long runs if it's stuck open. If it's stuck shut you'll overheat in no time...
Offline dom
  • Back in a Mk4
Lol. It does sound like thermostat btw. They are cheap as chips. I picked one up from ECP for £6. I would get one and change it and then see where you are with things.
Do not buy a thermostat from ECP, it will not last long at all. Mine was less than 2 weeks before it failed.
Offline Bellend
Buy a quality one from ECP if they do one. The cheaper range admittedly, as much as I rate ECP, are sh!t.
Where all my moneys went.
Offline WadGTI
  • Golf GTI'er
So in theory, If I am getting the cooling map error code, this should be cause by the temp sender?.
TBH,...I am wondering how the thermostat would cause a cooling map code to show up? as its mechanical rather than electrical? I reliease it would take a long time for the coolant to heat up with a stuck thermostat, however on a good long run, the temp of the coolant will hit and stay 90c?
Or am I just being silly?
Reason for saying this, I changed the temp sendor and still getting the ECO Cooling map code.
THanks
Offline WadGTI
  • Golf GTI'er
Actually guys, I have just answered my own question. Found this article on the net.
Some intresting reading on the cooling systems for our engines.
http://www.volkspage.net/technik/ssp/ssp/SSP_222.pdf
Offline dom
  • Back in a Mk4
THanks
When I had a cooling map fault code it was the thermostat at fault.
Offline Scott D
same fault code as well when thermostat
temps went to 90 when idling but once on the move dropped to 70ish - stat stuck open.
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
