Author Topic: How are you using your Chassis Control Option?  (Read 7392 times)
Offline dirvy
Re: How are you using your Chassis Control Option?
« Reply #10 on: 08 September 2013, 21:01 »
Early days, but like the sport steering setting.
Didn't spec chassis control, but option to change is on menu. Is this a mild version? Or just present on all in case specced
Offline CraigW
« Reply #11 on: 08 September 2013, 21:04 »
There are some different settings like sport and normal that standard to all the cars
Offline mcmaddy
« Reply #12 on: 08 September 2013, 23:26 »
all gti/gtd get the driver profile but you won't get the dcc unless specced
Offline Gung-Ho
« Reply #13 on: 10 September 2013, 17:56 »
I can tell you now... If you've opted for the 19" Wheel upgrade, the comfort setting will not the make the slightest difference to the harsh ride quality. To be honest I can't tell the difference between 'Comfort' & 'Normal'.
So far I've used 'Normal' mode the most and the individual setup with the following setup
DCC: Normal
Steering: Sport
Engine: Sport
Current Toys: Mk7 Golf R 5dr 'Manual', Lapiz Blue, 18" Cadiz Alloys... Caterham R300 Superlight... new Mazda MX5 2.0 SE-L (ND)
Offline Dully
« Reply #14 on: 10 September 2013, 18:58 »
DCC: Normal
Steering: Sport
Engine: Sport
I've gone for the standard 18" wheels so hope to feel some sort of difference in Comfort mode, will probably do the same as you and go for sport in the other options  :smiley:
Driving - MK7 GTD, 5 Door, CSG, DSG, Santiago's
