Author Topic: please help identify wires  (Read 4565 times)
Offline cooky
« on: 07 September 2013, 20:42 »
Hi fella's getting close with my wiring on my mk abf but just have a few wires I cant identify
First is a black/white from plug g2
Second is a black/red from plug g1
Also can I bin the brown earth or do I need it .
Next is the 3 pin connector off the engine loom above the gearbox
Thanks in advance
Cooky
Offline gazareth
Re: please help identify wires
« Reply #1 on: 07 September 2013, 22:32 »
orite man. is that a mk2 your putting it in?
Offline cooky
« Reply #2 on: 07 September 2013, 23:13 »
Yeah sorry its going in a 89 mk2 8v
Offline gazareth
« Reply #3 on: 07 September 2013, 23:21 »
ah rite. I think the plug near the gearbox is for electric speedo. that wouldn't be the golf that was parked in a garden in burnage by any chance? on the Kingsway near aldi?
Offline cooky
« Reply #4 on: 07 September 2013, 23:35 »
That's cool mate , will just tape it up out of the way for now .
Must be a different cat that one mate im 5 mins away from the traff centre
Any ideas on the on the other 2 wires
Offline gazareth
« Reply #5 on: 08 September 2013, 00:33 »
looks like fuse box plugs to me. if your car has the hazard light switch on the dash then its a ce1 electrics. if it has the switch between the clocks and steering wheel then its ce2. if its ce1 the plugs wont fit and will need splicing as the ce1 had round terminals and ce2 were flat. if your 5 mins from Trafford centre you could be within shouting distance of me lol. im just off princess road.
Offline cooky
« Reply #6 on: 08 September 2013, 12:14 »
Yeah its ce1 all the other wires are sorted and sliced in , just needed to find out if the white/black and the back/red are needed or wether I can chop them out , ive used the fusebox info on both fuseboxes but just cant seem to find the info on these 2 remaining wires ,  yeah your not to far for me mate
Offline gazareth
« Reply #7 on: 08 September 2013, 17:51 »
not sure on the others to be honest. do they go to the ecu? are all other sensors hooked up? and have you tried starting it yet?
Offline Ben@VWH
« Reply #8 on: 13 September 2013, 17:12 »
All the information you'll ever need :)   http://www.a2resource.com/electrical/CE2.html
3 pin plug is for the electronic speedo drive on an 02a box, just cable tie it out the way. If you have kept the original main earth for your ce1 fusebox then yeah you can ditch the ce2 brown earth wire.  :smiley:
Offline cooky
« Reply #9 on: 08 October 2013, 19:18 »
Thanks guys all sorted now , 38 black/white went to D2 and the 9 black/red was pin 86a ecu relay
