Author Topic: Things to replace with new shocks and springs  (Read 3902 times)
Offline Sgt_Lemon
  • 8v owners club
Re: Things to replace with new shocks and springs
« Reply #10 on: 10 September 2013, 22:09 »
Just wait until things do go them replace them with these suggested parts.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #11 on: 11 September 2013, 00:48 »
Did I not say "only use GENUINE PARTS"
Top Mounts Use A Set Of G60's.
I fitted a set of Genuine G60 mounts to mine some 4 years ago and still going strong today!
IMO Always use Genuine parts as they do seem to last much longer than aftermarket parts!! But You can still save a few quid if you can find OE parts like bistein or some febi parts!
but why replace parts that there is nothing wrong with? unneccesary expense I would say.
Simples do a job once and do it properly!!
Saves having to strip it all down again to replace a 10p part!!!
:afro:
For More Info Click To See;
Offline Diamond Hell
  • Opinions я Us
« Reply #12 on: 11 September 2013, 08:21 »
All this is worthless without getting it properly aligned afterwards.
-1.5 degrees of camber will help things along significantly over stock settings. Stitch welding the control arms will help things along too.
If you're into replacing bushes then mk1 TT bushes to the rear of the control arms will help too.
This will give you a snifter of lift off oversteer which is fun. .. provided you can drive  :wink:
