Author Topic: Rear caliper issue  (Read 2834 times)
Offline gazareth
Re: Rear caliper issue
« Reply #10 on: 04 September 2013, 20:28 »
that spiral thing inside the piston should rotate one way. kind of like a ratchet. it might just be sticky.
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
« Reply #11 on: 04 September 2013, 21:07 »
the spiral drive shaft thingy only twists a few mm on both calipers. these clearly work as they should as the good piston drives outwards when tried in both.
Offline gazareth
« Reply #12 on: 04 September 2013, 21:16 »
yeah but when caliper is in use the spiral only works 1 way. that's why you need to turn the pistons back in.
