Author Topic: boost gauges.  (Read 7052 times)
Offline sharki786
  • GOT BOOST??
Re: boost gauges.
« Reply #20 on: 18 September 2013, 10:52 »
Also is it worth me getting the duel pod or single? Might get oil temp gauge aswel
*****MK3 Anniversary*****
*****MK4 GTI T*****
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Offline mcgee9t2
Re: boost gauges.
« Reply #22 on: 18 September 2013, 12:58 »
well if you want an oil temp guage or afr guage or any other guage then get a duel pod... if not then dont...
are you going to use any of them?
someone i know has the following in his:
air fuel ratio
nos level
boost
oil temp
and i think air/nos ratio.
but he has a pretty highly tuned 600+bhp mr2 and does all his own ecu reprogramming etc so actually uses most of the read outs.
personally i cant see the need for any of them unless your going big power/have a stand alone ecu and do all the tuning yourself...
Offline dom
  • Back in a Mk4
Re: boost gauges.
« Reply #23 on: 18 September 2013, 13:07 »
I wouldn't bother with any other gauges to be honest.
Offline sharki786
  • GOT BOOST??
Re: boost gauges.
« Reply #24 on: 18 September 2013, 18:43 »
No point buying the oil temp gauge?
*****MK4 GTI T*****
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: boost gauges.
« Reply #25 on: 18 September 2013, 22:30 »
I only use my oil temp gauge to know when I can give the car some stick without doing it on a cold engine
Offline sharki786
  • GOT BOOST??
Re: boost gauges.
« Reply #26 on: 18 September 2013, 23:33 »
Ye thats same reason bud. You cant see the oil temp on the mk4s? Unlike the mk3 & 2s.
*****MK4 GTI T*****
Offline Nino
Re: boost gauges.
« Reply #27 on: 19 September 2013, 07:20 »
Tbh when the car is at full temp, the oil will be too
Current - MK6 GTi Edition 35 - Candy White - 3 door
Offline sharki786
  • GOT BOOST??
Re: boost gauges.
« Reply #28 on: 19 September 2013, 08:36 »
Not always as the oil takes longer to heat up dont it?
*****MK4 GTI T*****
Offline Nino
Re: boost gauges.
« Reply #29 on: 19 September 2013, 22:02 »
It does but it really is not far behind your taking min or two if that
