Author Topic: Compression figures  (Read 5804 times)
Offline gazareth
Re: Compression figures
« Reply #10 on: 04 September 2013, 18:05 »
How will they read lower with cam & head job? The valves are closed so no difference in compression
145 is too low, try a different gauge
so why do you think when you put in a cam with more duration and overlap they recommend upping the static compression ratio??? its because low rpm cylinder filling isn't as effective.
Offline Gambit
« Reply #11 on: 04 September 2013, 21:59 »
Lairy cams yes but fast road cams no
Offline gazareth
« Reply #12 on: 04 September 2013, 23:07 »
any uprated cam will make a difference. with a long duration cam the inlet stays open longer as the piston rises on the compression stroke pushing back out some of the air it has just drawn it.
Offline Gambit
« Reply #13 on: 05 September 2013, 07:46 »
As i said lairy cams yes fast road no
 look at kr, abf & autotech cam profiles. One has more lift, the other more duration and the later more of both and neither effect compression ratio
what cam is sgt_lemon running? Itd need to be a seriously big cam to have that much effect on compression.
Offline gazareth
« Reply #14 on: 05 September 2013, 22:01 »
kr and abf are 16v so you cant use them in a comparison between a standard 8v and a cammed 8v. not sure what cam the sergeant has but he reckons that once it was fitted his idle got very lumpy.
Offline danny_p
« Reply #15 on: 05 September 2013, 22:30 »
his gadge dosent stay up tho,  if it dosent have a valve init where it screws into the cylinder the colume of the pipe can be considerd to be part of the combustion chamber,  that will lower the compression ratio shown  LOTS.
145 is enough to run tho
all the VW's have gone bar 1.
Offline notenoughtime
« Reply #16 on: 06 September 2013, 08:37 »
I have a classic mini running a very lairy cam my compression gauge figures are about 280 per cylinder the overlap doesn't really affect reading
Op needs to use a gauge that works and then put his results up and we wouldn't all be going on about low readings in the engine
Offline Sgt_Lemon
  • 8v owners club
« Reply #17 on: 06 September 2013, 11:08 »
I have acquired another tester to settle it haha  :grin: if the sun comes out later I will test it again.
Offline gazareth
« Reply #18 on: 06 September 2013, 20:43 »
ok now we are veering of in a completely different direction again with talk of mad mini engines. but just out of curiosity. what is the static compression ratio of said mini?
Offline JC
  • Back in the North.
« Reply #19 on: 06 September 2013, 20:53 »
shall we get back on track  :wink:
Sarge, different compression Gauge required, then new readings please. :afro:
