Author Topic: Fixing a Flat Spot in the Rev Range  (Read 9397 times)
Offline RocketRossUK
« on: 27 August 2013, 09:07 »
Hey guys,
Just a quicky, just the other day i felt a big flat spot in 3rd while accelerating. It has been fine up till this point so i can rule the map out. It doesn't seem to happen all the time. Really need to take it on a full run with loads of 3rd and 4th gear pulls
Main thing i would check is DV, Coils, Plugs. Just dont which order is best to try. Obviously i should check Dv first, but my jack is broke at the minute, so cant just whip it up and check.
Has anyone else had a flat spot and changed any of the above with good results.
Offline barrym381
Re: Fixing a Flat Spot in the Rev Range
« Reply #1 on: 27 August 2013, 10:10 »
a jack to get to your dv  :undecided:
Offline Poached
« Reply #2 on: 27 August 2013, 10:19 »
Going to need VCDS or a logging session really as this could be a number of things.
What RPM is the flat spot?
Offline Rhyso
« Reply #3 on: 27 August 2013, 10:38 »
Its a MK6; its fitted at the back of the engine and underneath
Marshy
« Reply #4 on: 27 August 2013, 10:49 »
Ross I know you say its not the map but have you tried putting it back to standard to check?
Your bluefin aren't you? If so a quick easy check.
« Reply #5 on: 27 August 2013, 11:10 »
Its not map, it been pulling hard and fast for 2 months, wouldn't just change.
Its around 3000 revs. Im thinking it gonna be a teared DV, I remember when it happened on my MK5, think it did the same.
I have VCDs, what menu do you use to test boost / flatspots?
Offline Rhyso
« Reply #6 on: 27 August 2013, 11:19 »
Engine module
Think boost is block 110 / 115
Or they start at block 10
« Reply #7 on: 27 August 2013, 11:34 »
Engine module
Thanks for the reply. Then what do you do with it? does it show you fault or lack off boost etc...
Offline Poached
« Reply #8 on: 27 August 2013, 12:23 »
Firstly see if you have any faults stored in the ecu memory.
Then you could measure boost pressure requested vs actual boost pressure produced with N75% (Wastegate).
There are many variables you can measure in VCDS. You are probably best exporting the data to excel and producing a graph to see what's happening or taking it to a tuner with a dyno to test in a controlled environment.
« Last Edit: 27 August 2013, 12:25 by Poached »
Offline Rhyso
« Reply #9 on: 27 August 2013, 12:46 »
As per Poache's reply  :smiley:
It will give you specified VS actual values so you will see if you are losing boost  :nerd:
