Author Topic: Cycle Rack - VW Roof Bars or Thule aftermarket?  (Read 74815 times)
Offline monsta
Re: Cycle Rack - VW Roof Bars or Thule aftermarket?
« Reply #10 on: 27 August 2013, 11:08 »
No fancy tow bar for the UK market and might not even be possible with the GTI bumper says the dealer...  :cry:
Offline rick2b
« Reply #11 on: 27 August 2013, 11:51 »
I had a quote of wait...... £1100 supply and installation of a towbar kit through VW.
Not too sure what type of towbar it was as I went no further with this after collapsing.
Think it may have been like the pop down version with pull handle in the boot, or whatever.
The dealer did however put me onto a local towbar specialist/spanner who'd do it for about 360quid. I have not gone down this road as yet because I don't fancy some grease monkey cutting a hole in the rear panel and it all going pete tong :undecided:
« Last Edit: 27 August 2013, 12:00 by rick2b »
Mk7 Golf GTD Oryx White 19''rims 3dr keyless
Offline Buck
  • Das Auto
« Reply #12 on: 28 August 2013, 00:25 »
I've got a towbar on my Mk6 GTD - it is removable and the lower bumper fascia has a clip in panel which makes it look almost original when not in use.
We only use the towbar for lugging the bikes around so didn't want a permanent fit.
I had it fitted in Bradford - not sure how far away that is from you?
Offline Buck
  • Das Auto
« Reply #13 on: 28 August 2013, 00:27 »
Offline monsta
« Reply #14 on: 28 August 2013, 13:46 »
Offline Buck
  • Das Auto
« Reply #15 on: 28 August 2013, 20:50 »
Similar to this
http://youtu.be/IjpMwzmcrno?t=1m5s
How much was that setup?
£450 including towbar, fitting and the new valance
Offline Carlosmonkey
« Reply #16 on: 31 August 2013, 07:36 »
Hi all new to forum.  Try having a look at the prorack whispbar with flush mounting and the thule 591 cycle carrier,I have it on my mark 6 gti and people comment on how good it looks.
driving mark 6 gti
on order,gtd carbon steel grey,dynaudio,park assist,sat nav
Offline monsta
« Reply #17 on: 31 August 2013, 12:02 »
Welcome and thanks for the input :)   The whispbar does look nice, they don't seem to have one for the mk7 yet but I'm sure it's a matter of time.  How much was your setup on the mk6?
Offline monsta
« Reply #18 on: 17 September 2013, 22:08 »
Heads up, if anyone is after a set, there are some 5 door ones on ebay right now - get yourself a bargain
http://www.ebay.co.uk/itm/GENUINE-VOLKSWAGEN-GOLF-MK7-5-DOOR-ROOF-BARS-5G3071126-/221281789137?pt=UK_Car_Accessories_Touring_Travel&hash=item33856c24d1
Offline lawrie
« Reply #19 on: 18 September 2013, 17:56 »
I had a slightly cheaper quote from dealer but it was still expensive so I  went to fitter they recommended.  Towbar fine but could not code correctly as he did not have the latest software.  A complete shambles.  Dealer did not want to know..problem with warranty they said, wanted to charge for diagnostics etc etc.
Got the fitter firm to remove everything and got a refund.
Paid another VW dealer £900 for the same Westphalia detachable kit but they coded it correctly and to be honest, I was happy.
The Mk6 system of a detachable piece in the rear valance is not (as yet) available for the Mk7.  VW do supply a different valance (£90)! which I have and the hole cannot be seen.  Quite neat.
Also got a Thule easifold bike carrier (tow bar) and that is terrific.
