Author Topic: Bhp gains after map.  (Read 2712 times)
Offline Tezmax
« on: 17 August 2013, 13:40 »
Maybe a silly question but if you add Silicon pipes, Sports exhaust/down pipe, de-cat, dv 007/8 etc after your remap, will you increase your Bhp or will it only produce what it reached during its original R/road run.
Obviously a stage 2 map would be on the cards but would there be any gains before you take that step?
Thanks.
1.8t Aum. forge 007p. 17" bbs. R-tech stage 1 map.205/235. catch can.
Offline rio_gti
Re: Bhp gains after map.
« Reply #1 on: 17 August 2013, 14:43 »
It'll run like a dog.... Take that from Experiance!!!!
It will need to be mapped after those changes are made to benefit
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 18 August 2013, 00:43 »
With a decat, 007p, full exhaust and filter I got 174bhp on a standard map
Offline Scott D
« Reply #3 on: 18 August 2013, 10:12 »
Mine ran fine on a standard map with all the usual stage II mods, 15bhp increase I got.
Obviously a lot better once mapped
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline dom
  • Back in a Mk4
« Reply #4 on: 19 August 2013, 21:31 »
When mine was first mapped it only had a 007p and panel filter and made 202bhp. I've since added 3" downpipe with Milltek cat back, Venair TIP and boost hoses and S2000 air filter, after logging MAF readings it is pulling 175g/s now which is roughly 220bhp.
I need a stage 2 map now though as I've fitted a FMIC and have an S3 fuel pump waiting to go in :cool:
Offline GTi_James
« Reply #5 on: 20 August 2013, 17:14 »
nut case  :grin:
Offline Prawny
  • R-tech power!!!
« Reply #6 on: 21 August 2013, 12:07 »
should run fine after adding those small extras still.
i had my AUM mapped to st1 and had the post cat lamda mapped out at the same time, and it made 196bhp on a totally stock car.
I added a 3' DP and decat, jetex filter, silicon TIP, and an N249 bypass, and it ran 224bhp on the same dyno with no map alterations.
