Author Topic: So, now you've got a few miles on the clock...  (Read 10414 times)
Offline SRGTD
Re: So, now you've got a few miles on the clock...
« Reply #20 on: 15 August 2013, 22:26 »
Assume too far back to be this? Highlighted on Honest John Motoring site.
Latest Update Volkswagen Golf 2013: Seems to be a problem of "rattling" rear dampers on more powerful Golf VIIs fitted with multilink rear Sports suspension, including the GTI. The fault is with the dampers themselves because it disappears if they are removed.
I had a noisy rear suspension on my mk6 GTD, and turned out to be the rear dampers. Replaced by the dealer under warranty, and problem solved.
Gone but not forgotten;
2016 Polo GTI; Blue Silk
Offline CraigW
« Reply #21 on: 16 August 2013, 07:36 »
It's definitely not the rear dampers. I went out to do some further investigation last night and the noise that I'm hearing appears to be coming from the driver window and the rubbet seal I think. It's the strangest thing, when your siting directly behind the driver you can't hear anything so it's just the driver that's affected  :cry: :angry:
Offline mk7gti
« Reply #22 on: 16 August 2013, 09:53 »
Would some silicon spray sort it :smiley:
MK7 GTI - Deep Pearl Black - Standard Spec - Ordered 10/12/2015.
MK7 GTI - White - Standard Spec - Service Pack - Collected 11/09/2013.
