Author Topic: e36 M3 3.2 evolution  (Read 164347 times)
Offline Waspy
Re: e36 M3 3.2 evolution
« Reply #70 on: 25 March 2015, 12:37 »
Those wheel mannnn
Offline tweed
« Reply #71 on: 29 March 2015, 20:44 »
Today I used a vacuum bleed kit to try and suck some air out the lines. As having trouble with a spongy pedal.  Pedal is firm when cold and once warm it does goes soft. Definitely shouldn't be brake fade with the xp8's and plus if I pump the pedal, it does go firm again.
Typically it starts to rain as soon as I take wheel off. Needed a shower anyway lol
so didn't really take any more pics because it was like trying to use your phone under water.
Also thought I would try tightening the brake lines, and got bit of a turn on them.
Still need to go out and test them. If it still persists then it may be master cylinder, but this looks like a new item and not the original from 1998.
also decided to have a little tinker and check ICV and vacuum pipes.
what a fiddle little job that was! Not if you got tiny little girl hands , but big fat cock fingers its tricky.  Plus the last bastard that worked on the damn thing thought he would have a laugh and put all the jubilee clips on with the screws facing the back of the car. So with a few c words and patience tested I got it off.
Then the inner child came out and I thought about running the trumpets upside down sticking out the bonnet.
ICV taken out and cleaned with carb cleaner.
And the H&R arb mounts installed
Thats all for today :)
VW BUSH
« Reply #72 on: 29 March 2015, 21:12 »
That does look like a newly fitted Servo the ali still looks fresh from the bead blaster....
Could be a recon?
Offline tweed
« Reply #73 on: 29 March 2015, 23:24 »
Could be a recon?
Never thought of that and don't have history of it being changed. Its possible.
Don't know how much a genuine one is but can get them for £170 so not too bad.
Offline tweed
« Reply #74 on: 14 May 2015, 22:06 »
Abs was playing up and after a year of playing hide and seek with the abs light, it finally stayed on long enough to run a test.
Front right speed sensor.
20150418_172037 by tweedub, on Flickr20150418_172030 by tweedub, on Flickr
New pagid going in
20150418_172409 by tweedub, on Flickr
Noticed the holes in the disc's was blocked. Could be the carbotech xp8 pads as very dusty, but worth checking yours!
20150418_171355 by tweedub, on Flickr20150418_171359 by tweedub, on Flickr
Also see a little crack. Disc's have only done 5k
20150418_171041 by tweedub, on Flickr
So now I've got the dreaded vanos fault. It's got a loss of power low revs. Thought is was solenoids, but all checked and are fine.
20150501_195051 by tweedub, on Flickr
20150426_205346 by tweedub, on Flickr
I have ordered the uprated rubber O ring seals from Beisan. Kit is $80 and express delivery is $47. Need it done before the ring in 3 weeks.
Also changed gearbox oil.
20150428_185810 by tweedub, on Flickr20150428_193158 by tweedub, on Flickr20150428_193205 by tweedub, on Flickr
Gearbox oil may look black but was quite clean. So good sign car has been looked after ;)
Next up will be vanos rebuild and a oil service.
All this is done at 67k
20150429_200632 by tweedub, on Flickr
Offline tweed
« Reply #75 on: 14 May 2015, 22:08 »
Got my GB plates on ready for Germany
I hate a front plate
20150505_195945 by tweedub, on Flickr20150505_201208 by tweedub, on Flickr
They are the wrong front and that's my mistake!  I'll order the correct font when I get back.
Also the strut braces and oil got delivered in 24 hours.
20150506_212629 by tweedub, on Flickr20150506_184549 by tweedub, on Flickr20150506_184558 by tweedub, on Flickr
Will get these on tomorrow hopefully.
So oil service will be just under 5k from the last! But I've just changed gearbox oil and will be doing vanos and valve shims, so may as well be inspection 2 service.
Anyway I got Fuchs titan race pro s 5w40 again. It was £53.95 for 6 litres from demonstweeks. Love a bargain
20150506_231719 by tweedub, on Flickr
Offline tweed
« Reply #76 on: 14 May 2015, 22:12 »
Strut braces. Should be an easy job! Well not for me!
First of all as you can see from picture above. The bolt was 6mm to long
20150507_193109 by tweedub, on Flickr
Then this bracket and weld are in the way. Tapped the little ****e down with a big hammer.
Still needed the grinder though. Grinders and hammers solve everything
20150507_195431 by tweedub, on Flickr
20150507_201153 by tweedub, on Flickr
20150507_201430 by tweedub, on Flickr
Ooosh!
20150507_203442 by tweedub, on Flickr
Offline tweed
« Reply #77 on: 14 May 2015, 22:14 »
Time for Service
20150510_210006 by tweedub, on Flickr
So last service  (spec 2) was 5k ago. This will be spec 2 too. Doing valve shims vanos rebuild and just changed gearbox oil.
Out with the old
20150510_190228 by tweedub, on Flickr
20150510_190653 by tweedub, on Flickr
In with the new
20150510_204019 by tweedub, on Flickr
And a reset
20150510_210707 by tweedub, on Flickr
Offline tweed
« Reply #78 on: 14 May 2015, 22:16 »
Well last few days I've been fitting the rear strutbrace :muttley:
I got a cheap £35 ebay rear brace but when I tried fitting it, it didn't quite fit. I had a look and it seemed two holes had been drilled in the wrong place. After emailing the seller a few times to come to a solution, I noticed I in fact bought a e46 rear brace :roflmao:
So with e36 rear braces starting at £90 and short time scale before the ring, I thought I would make it fit!
20150512_201138 by tweedub, on Flickr
Cleaned up for earth and welding
20150512_202055 by tweedub, on Flickr
20150512_202059 by tweedub, on Flickr
I didn't have copper to clamp to it so welding wasn't that neat.
20150512_210457 by tweedub, on Flickr
Cleaned up with grinder
20150512_211816 by tweedub, on Flickr
Marked up for drilling
20150512_212732 by tweedub, on Flickr
Now holes in the right place for e36 :)
20150512_214936 by tweedub, on Flickr
Just to make sure. I traced the good one then placed the newly drilled one on top. Perfect!
20150512_214201 by tweedub, on Flickr
So now I needed to cut the bar down 40mm. 20mm each side
20150513_190428 by tweedub, on Flickr
20150513_190437 by tweedub, on Flickr
Now I needed to tap out the holes another 20mm each side. I didnt have a 14mm tap so used the bolts with a vice and a big adjustable spanner
20150513_192722 by tweedub, on Flickr
You can see the new cut threads
20150513_192711 by tweedub, on Flickr
And there we have it. A e46 rear strut brace in a e36 coupe :muttley:
20150513_193606 by tweedub, on Flickr
Oh I did paint it with smooth black hammerite too.
Tomorrow will be carbotech xp8 rear pads. And new drop link bracket on front coilover.
Stay tuned b!tches :peace:
Offline tweed
« Reply #79 on: 30 May 2015, 23:39 »
So the droplink bracket is made of chocolate!
I think that it may have came loose and the fact I have a 28mm H&R anti roll bar, it may have weakened the bracket
20150515_193955 by tweedub, on Flickr
20150515_194019 by tweedub, on Flickr
20150515_201805 by tweedub, on Flickr
Got on the phone to driftworks explaining the issue and they sent a new bracket out straight away free of charge!
20150515_201936 by tweedub, on Flickr
20150515_201933 by tweedub, on Flickr
Next was to take bottom hub brakes off and fit drop link bracket. Was really tight so found a bar :)
20150515_200554 by tweedub, on Flickr
20150515_200548 by tweedub, on Flickr
20150515_203645 by tweedub, on Flickr
Whoop all done. Well since this my mate turned down some 3mm thick stainless washes. 30mm with 10mm centre. Will take a pic tomorrow.
Carbotech xp8 rear pads
Easy to do. Undo rear caliper from carrier. Push piston in with thumbs and put in new pads.
20150515_173704 by tweedub, on Flickr
20150515_173700 by tweedub, on Flickr
