Author Topic: coil pack/spark plug removal on golf mk4 1.6 16 v?  (Read 17263 times)
Offline mar_k
Re: coil pack/spark plug removal on golf mk4 1.6 16 v?
« Reply #10 on: 14 August 2013, 18:52 »
You can pry them out with a flat head screw driver, Done it many times on a 1.4 16v which is identical to
the 1.6.
Offline sps
« Reply #11 on: 14 August 2013, 21:03 »
the 1.6.
ok, does one have to remove the plastic surround which holds the wiring held in by 2 torqs screws before using the flat head screwdriver?
Offline sps
Offline sps
« Reply #13 on: 03 September 2013, 17:47 »
the above tool arrived today.
did the job perfectly :grin: even though the draper packaging in whch the tool came did not mention the golf 1.6 ,it mentions golf 1.4 which has similar ignition coils to the 1.6 engine.
« Last Edit: 03 September 2013, 17:49 by sps »
