Author Topic: Advice needed...  (Read 1738 times)
Offline motherkennedy
Advice needed...
« on: 10 August 2013, 09:17 »
Hi all, I'm new to here and need some advice.  I have not long brought this 2001, 1.6 vwgolf mk4, when it gets to tempreture the oil light comes on so having done a bit of reading it looks like the oil pump needs replacing.  Is this a do-able job? Any advice would be great.
My husband and son have not long replaced the radiator and the thermostat.
Thanks
motherennedy
Offline slappycarr
  • slappy
Re: Advice needed...
« Reply #1 on: 14 September 2013, 03:15 »
i have had the same problem with my 1.8 turbo mk4 gti on a 2000 the oil light came on even though there was enough oil in so i took off the oil sump and the oil pump was broken the bolt that holds the cog on had snaped so i changed it and it snaped the other one yours might just be the gause in the end is blocked it is do abull but ti is a regular problem with golfs
mark carr
Offline notenoughtime
« Reply #2 on: 14 September 2013, 17:22 »
Common problem with gauze getting blocked, drop the sump and check it out
