Author Topic: Ride height  (Read 7733 times)
Offline caprigreen
Re: Ride height
« Reply #10 on: 17 August 2013, 18:22 »
I am sitting about 300mm at the front and 275 at the rear. If I could raise the rear 25mm I thin it will look about right. Not sure how much the mk3 top mounts would gain me
64 plate VW Golf GTI PP Pure white
1991 VW Golf GTI 8v Silver, 30k miles
Offline Gambit
Re: Ride height
« Reply #11 on: 22 August 2013, 17:17 »
nowt as its only the front top mounts you replace with mk3 items which will raise the front about 5mm or so.
if you think its the springs then replace them. but replace the rear rubber spring cups also along with top mounts shocks wont make a difference to height
Offline caprigreen
Re: Ride height
« Reply #12 on: 07 September 2013, 16:37 »
Gents,
Hope everyone is well.
Would like your opinions. I have been trying to sort out my suspension and decided upon some eibach springs (pro kit). Just taken off the rear shocks (boge turbos) and checking the part number 27-528-F it says they are for a 16v not a 8v, will these be ok with the eibachs?
 Just looked at the front socks and they are sachs . I have a mixed shocks front and rear , they all look new so if the boge rears are ok I could buy a new set (boge) for the front or stick with the front sachs and buy some new sachs for the rear. Any opinions guys ?
Steve
PS the more I look the worse it gets !
Offline GeordieChap
Re: Ride height
« Reply #13 on: 07 September 2013, 19:11 »
Just fitted Sachs rear shocks and eibach pro springs to rear on 16v looks spot as suggested by Gambit very close to standard as well highly advisable bud.
Offline gazareth
Re: Ride height
« Reply #14 on: 07 September 2013, 22:48 »
if all your shocks are ok then just change springs. there wont be much difference in boge and sachs shocks anyway.
Offline caprigreen
Re: Ride height
« Reply #15 on: 08 September 2013, 12:55 »
I find it strange that the rear shocks need to be different for a 16v when the ride height is only 10mm lower.
Offline caprigreen
Re: Ride height
« Reply #16 on: 09 September 2013, 21:33 »
Hi all
I put the rear eibachs on today and she sits 325mm from wheel arch to centre of the hub all round. Looks spot on , should really do the fronts now as no idea what the springs are on the front.
Offline Sgt_Lemon
  • 8v owners club
Re: Ride height
« Reply #17 on: 10 September 2013, 16:08 »
If you like the height I wouldn't touch the front. If it isn't broke, don't fix it.
Offline caprigreen
Re: Ride height
« Reply #18 on: 10 September 2013, 17:34 »
Thats my dilemma I just have a bit of a problem with having a mixed set up. I think you may be right
Offline Gambit
Re: Ride height
« Reply #19 on: 13 September 2013, 18:51 »
Put the fronts on also
