Author Topic: Should I upgrade my MAF? Mk2 1.8t AGU Ko3s Conversion  (Read 1690 times)
Offline higgins
I have a golf mk2 with an AGU Ko3 and i am currently getting the parts ready for a ko3s conversion.
At the moment I have the KO3s Turbo and Saab redtop injectors.
I need to get a new MAF as my current one isnt running 100% as i found out when i first mapped it. I cleaned the sensor and put it back in as i thought i may aswel upgrade when I go Ko3s.
But instead of going the standard AGU MAF, Should I go Vr6 maf? Or will the AGU Maf easily cope with the ko3s?
Offline Roystar
Re: Should I upgrade my MAF? Mk2 1.8t AGU Ko3s Conversion
« Reply #1 on: 08 August 2013, 20:22 »
You will need to change the housing to 3" keep the existing/new MAF sensor. when you put the injectors in change the housing at the same time or she run rich best to do that just before or at your mappers.
